Ninja |
Ninja Caption Abuser
Posted: 09:48 - 07 Sep 2004 Post subject: Advice needed - taking my GPZ9's wheels off |
Hi - the GPZ needs a new set of tyres so I want to take the wheels off the bike to take them to the tyre place (also using the exercise to get used to spannering on the bike).
I would probably be able to do this easily enough, but have never taken the wheels off a bike before - as I don't have a workshop manual yet would anybody be able to give me some basic instructions? I'd appreciate it - especially if there's any specific things you have to do with the eccentric-cam adjusters on the rear.
Cheers in advance ____________________ James
4 wheels transport the Body ... 2 wheels transport the SOUL |
Big Pete |
Big Pete Spanner Monkey
NickD |
NickD World Chat Champion
Ninja |
Posted: 14:08 - 07 Sep 2004 Post subject: |
thank you guys
@Big Pete - nowhere seems to stock the GPZ900R (or derivatives) manual and the tyres arrive tomorrow . . . ____________________ James
Ninja |
map |
map Mr Calendar
Ninja |
Posted: 14:21 - 07 Sep 2004 Post subject: |
haha - cheers - I saw it earlier as I looked for a manual - I wonder if he'd take offence if I asked him to 'demonstrate' it works by emailing me copies of the relevant pages and torque settings . . . ____________________ James
Big Pete |
NickD |
Ninja |
Posted: 14:28 - 07 Sep 2004 Post subject: |
The Library! - Genius! - The most overlooked resource of the day/ week/ month/ year . . .
I'm happy to do any kind of work really and think I'm competent enough; I just don't want any dodgy surprises as 'quirky' bits spring apart in my hand . . . . . . or find that I've been resolutely trying my hardest to tighten a reverse thread bolt.
Ta ____________________ James
ZRX61 |
ZRX61 Victor Meldrew
Posted: 03:30 - 08 Sep 2004 Post subject: |
Assuming bike is on the main stand:
Loosen the eccentric pinch bolts
Rotate the eccentrics forwards to get max slack in the chain
Re-tighten pinch bolts
Stick some wood under the wheel so the tire is just touching it.
Remove chain guard
Lift chain off rear sprocket & move it over to the left
Remove the axle nut (should be on the right side)
Slide the axle out
Pull wheel backwards
remove the spacers on each side of the wheel & remember where they go.....
& then wander off to tire shop
& to quote Kawasaki: "Assembley is the reverse of disassembley"
If ya have a washer left over you failed the test.......
.. it goes under the axle nut on the right side.
any questions? |
Ninja |
ZRX61 |
Posted: 22:23 - 08 Sep 2004 Post subject: |
Ninja wrote: | . . . I gave up as I couldn't quickly figure the rear after slackening the pinch bolts and trying to rotate the cams/ eccentrics and also found I would need a second hex socket/ allen key to take the front off, which I don't have.
but does the rear caliper bracket have to be loosened to allow the movement?
Now I'm a little confused - the spindle (axle) looks like it might be secured with a hex-head bolt on each side?
Hammer and drift required?
cheers for the info |
The front should be 17mm which is the same as a VW oil pan drain plug. Halfords should have one.. failing that.. the 3/8 drive one from Snap-On costs about $13.00. Leave the other (larger, 22mm?) side pinch bolts tight until ya get the nut off (which should be on the left side).
You can finagle the caliper etc out of the way, drop something between the pads to hold em apart until you get the edge of the rear brake rotor in for ease of assembley.
The rear spindle nut is also a hex head, the smaller of the 2 is the actual spinle, the larger one is the nut.
Brass drift is needed soemtimes, I usually just push the spindle out with the ratchet handle. Be sure to grease both spindles before ya put em back in & clean any corrosion off em also.
The reason ya need a bit of wood that *just touches* the rear tire is because the new tire will be taller & ya won't have to worry about supporting the weight of the wheel etc as ya put the spindle back in..
& make sure ya correctly install the spacer inside the cush drive housing. It fits either way, but one way is wrong.... (thats the bit that fell out as you were pulling the wheel out.... narrow at both ends with a ridge slightly off center)
So ya need a 8mm allen for the pinch bolts, a 17mm for the front axle & a 12mm to rotate the eccentrics/rear axle nut. |
Ninja |
ZRX61 |
Posted: 23:01 - 09 Sep 2004 Post subject: |
Rear: The smaller hex is the spindle, the larger one is the nut so at elast we know the last guy put it back in the right way, the spindle comes out on the chain side. LM grease is fine for the spindles.
As for the rear caliper nut: Some people just leave it a bit loose anyway. It ain';t like it will fall off as it's supposed to be a nyloc nut anyway.. & the bolt should have a pin thru it outboard of the nut..
Front: ya suposed to put something under the front of the engine to keep it balanced, a pile of 4x8's works. Isn't hindsight wonderful?
Pops???????????????????? |
The last post was made 19 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
