CG 125 rumbling from crankcase
speedingmotor...
PostPosted: 17:57 - 17 Oct 2017    Post subject: CG 125 rumbling from crankcase Reply with quote
hello BCF and Teflon Mike
I have a CG125 that a friend gave me 1979 the year, it is making some vibrations and loud rumbling when accelerating and at speed. when i pull in the clutch its a rather smooth ride, which leads me to believe there is a problem with the chain sprocket, clutch or gearbox. I have the clutch puller and I am thinking of breaking down that side of the motor.
EDIT: does anybody have ideas about how to go about troubleshooting the rumbling and rough vibrations?
anything i should look for? or am i an idiot
Karma
https://www.youtube.com/watch?v=zojEIR_SGSk
Commuter_Tim
PostPosted: 20:12 - 17 Oct 2017    Post subject: Reply with quote
speedingmotorcycle wrote:
hello BCF and Teflon Mike...
Oh you son of a bitch, you have no idea what you just did. Laughing
Inb4 loose engine mount bolt. (...and a serious Teffing no doubt)
It happens curiously often with CGs though.
Chain you can easily rule out, just be meticulous checking your chain tension all the way around (plenty of guides on the intarwebs).
Then wiggle each link and make sure none are rusted tight or massively loose/damaged.
It's highly doubtful anybody chucked an Oring chain on a CG, so no worries there.
It couldn't hurt to whip the wheel off and check the cush drives too (rubbery stuff that sits behind the rear sprocket to dampen vibration)
I ride a Bandit 600... badly.
mauzo
PostPosted: 10:51 - 18 Oct 2017    Post subject: Re: CG 125 rumbling from crankcase Reply with quote
Check the stand isn't contacting the chain when it's up.
'04 CG125, '07 CBF500
speedingmotor...
PostPosted: 12:16 - 18 Oct 2017    Post subject: Reply with quote
hey thanks for the replies
i assume you mean the kick stand?
i checked and found one kind of loose, i cant seem to find in the haynes manual how many there are :-0
speedingmotor...
PostPosted: 15:40 - 18 Oct 2017    Post subject: Reply with quote
Karma Karma Karma
tightened that bolt and now its sooooo smooth
Smile
thanks BCF (and of course Teflon Mike)
mauzo
PostPosted: 19:29 - 18 Oct 2017    Post subject: Reply with quote
If you've got both, then either stand. Mine only has a centre stand.
The last post was made 6 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 17 - Page Size: 52.11 Kb
