kal9001 |
kal9001 Trackday Trickster
Posted: 18:25 - 18 Oct 2017 Post subject: CBF125... STILL won't start... |
Okay, same old story...
Bike cut out on the GF on her way to work. She got it going again once, then it died again within a mile and won't start again.
It turns over, there is a minor rumble and sometimes it almost sounds like the engine is taking a little slack off the motor, but never actually starts.
The bike will bump start, but has notably poor power, and will die again as soon as you let the revs drop under about 4k or drop the throttle under about 1/3.
We have had the injector out and noticed the spray pattern looked a little heavy, so we replaced the pump. this has made a big difference and the injector now emits a fine mist and projects it much further. as I would expect.
We have checked the plug it seems in good order, with a strong spark.
Ive checked valve clearances but have no other means to check compression other than a finger, it's got some compression, but no was to know how much.
Any idea's what to check next? Its only done 1000 miles, though it was stood for a while its done 500 of those miles recently so its not like its got stale fuel or seized :-/
Getting pretty fed up of this bike now and really desperate for a solution, ferrying her to work in the car is expensive on fuel. ____________________ Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs! |
Copycat73 |
Copycat73 World Chat Champion
nowhere.elysium |
nowhere.elysium The Pork Lord
Posted: 19:39 - 18 Oct 2017 Post subject: |
kal9001 |
jaffa90 |
jaffa90 World Chat Champion
Nobby the Bastard |
jaffa90 |
kal9001 |
Posted: 09:36 - 19 Oct 2017 Post subject: |
Yea, with the old pump it looked like it was chucking fuel with a bucket. so we though it was that. Changed the pump, and in the process had to swap the fuel lines too as they felt like they were made of cheese and pretty much disintegrated :-/
So... I have no means to properly check the ignition timing, As for the valve timing, had the rocker cover off and checked valve clearances, again no feeler gauges but it feels like what you should expect (I've had experience building (and breaking) beetle engines) At the same time I can see and feel that the cams aren't doing anything bizarre, the rockers are working, the chain is still on, and turns freely without any noise, there is wet oil around the inside so it is feeding oil up into there.
If its an electronic issue then it has to be timing, the coil and plug do appear to work, though I will try swapping the plug as suggested anyway, but I can't check the actual ignition timing any way, but then how could that so off so badly it won't start, but then close enough it will bump start :-/
Compression is my other thought, if a valve or valve seat may be cracked, or a piston ring has annihilated itself O.o cross that bridge when we get to it.
As for the exhaust system... I could try running it with the pipe off, but I don't think thats the issue, there is noise coming from the tail end, and a small puff of air... oddly though, there doesn't seem to be a strong smell of fuel in what comes out. but fuel is defiantly going in... ____________________ Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs! |
Paulf |
Paulf Nova Slayer
ZaphodBeeble |
ZaphodBeeble World Chat Champion
Posted: 03:14 - 25 Oct 2017 Post subject: |
Do the compression test. If it's low I recommend checking/adjusting the valve clearances as they will probably be tight. ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
kal9001 |
Posted: 10:18 - 25 Oct 2017 Post subject: |
ZaphodBeeble wrote: | Do the compression test. If it's low I recommend checking/adjusting the valve clearances as they will probably be tight. |
Already checked the clearances, think I mentioned it. They feel as good as I can tell without a proper feeler gauge.
Update is... swapped the plug, no difference, swapped the fuel no difference, dropped the oil and no bits came out, just surprisingly clean oil... And then.... drum roll....
Randomly took out the air filter, though it looked fine anyway... and surely it's not an induction problem as I would expect it would have started when we tried simply aiming the injector down the intake bore that one time... but alas... with no filter in it it fires up, put the filter back in and it dies. seems though the filter LOOKS okay, the paper material has gone stiff like that crappy chipboard they give you to put on the back of wardrobes and stuff and probably about as permeable as it...
So its still not 100% happy as it won't idle properly, it will tick over for 5-10 mins then just putter out. Tiny blip on the throttle and it springs back to life for a 30 seconds then same again... Its like a bored child :-/ though as shes now riding it again the problem seems to be slowly going away, my guess could only be a stuck IAC valve/motor that's slowly working its way free again now its being used once more.
Now I have that nagging issue.... am I happy its back on the road, or am I annoyed that all of this bollocks was all just over a god damn stale air filter!!! ____________________ Anyone stupid enough to think we will drag a load of wooden horses full of soldiers into our city is certanley stupid enough to drag all of ours into theirs! |
ZaphodBeeble |
The last post was made 6 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
