DRZ4Hunned |
DRZ4Hunned World Chat Champion
Posted: 11:12 - 23 Oct 2017 Post subject: Hole in crankcases, JB weld? |
I had a crash a few months ago, so I'm in the process of getting the FZS600 back on the road. Unfortunately the crank cases were cracked where the surface meets the starter clutch cover. The impact caused the bolt to rip the casting out and has left a hole.
Is this area of the engine under high oil pressure? I was thinking maybe just use some JB weld or similar to repair it? Hopefully the other bolts will be enough to prevent a leak?
https://i.imgur.com/xiWF7yJ.png ____________________ DRZ400-SM
FZS600 |
solemnwarning |
solemnwarning Borekit Bruiser
Beehive Bedlam |
Posted: 12:03 - 23 Oct 2017 Post subject: |
Sounds like a job for aluminium solder.
If there is a crack, you'll need to drill a stop-hole to prevent the crack propogating further then fill the crack and the hole.
You can fill huge defects with aluminium solder, you can also file it back flush, drill it and tap it.
You'll need a good source of heat like oxyacetylene or MAP gas (and some practice, the old cover would likely work if it's also alloy).
Durafix is a good brand.
https://youtu.be/n1njyuPBIH0 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
DRZ4Hunned |
Posted: 12:52 - 23 Oct 2017 Post subject: |
solemnwarning wrote: | Has it created a new hole, or merely pulled the threads out? If there's enough metal left, and the hole isn't an oilway or something, a helicoil might be an easy (and strong) solution. |
If you look at the bottom left most bolt, you can roughly see where it's ripped the bolt out and taken a chunk of casing out with it. I'd say the hole it's made is about 1cm^2.
Quote: | I wouldn't trust JB weld.
Buy my scrap engine. 50 ponds. |
Tempting, but you're miles away.
Cheers, I'll look into that. [/quote] ____________________ DRZ400-SM
FZS600 |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 15:57 - 24 Oct 2017 Post subject: |
JB or Lumiweld etc can do a fantastic job, but the devil is in the detal, and like a lot of DIY not in the job, but the prep.
Crank-Cases generally don't have to stand too much 'stress' just keep the oil in, and I know of pistons fixed with Lumi-Weld, so it can stand some stress.. but its all dependent....
To do that job justice, I would probably want the motor torn down to the bare cases, so that I could first get them clean enough that I wasn't cooking oil oil and crap into the joint, and getting the heat into the case I wasn't cooking critical rubber seals or paper gaskets somewhere in there...
Full tear down, would make me ponder the merit of trying to salvage damaged crankcases, vs cost of replacing, nw or 2nd hand.
NOT tearing down... trying to fix in situ... I would be pondering the potential savings of not tearing down, vs the risk that working around whats still i situ would make the job more of a ball-ache, and likely result in it having to be done, and re-done and never getting properly done.. and in that, the merits of going a cold-cure, using a loaded epoxy, either a propriety gloop like metal-set or a home brew using araldite and aluminium filings etc, which will never be as good as an ali-weld or solder, but can do the job adequately if the wound s clean enough and the area not under too much stress.. a 'strategic' bodge basically. But even there, the prep is the key, and cleanliness next to sodliness, a full tear-down may still be in order, and alternative cases the better solution....
Your call....
Top tip... make sure there's o rocks around when you drop a dirt bike.. always look for the 'soft' landing! That's my advice... cant say I follow my own advice very well, judging by the amount of araldite and lumi-weld in my own dirt bikes over the last 30 years... bludi CoC's always find ROCKS to stick a section round! But still! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
DRZ4Hunned |
raesewell |
raesewell Traffic Copper
monkeyman |
monkeyman Scooby Slapper
Beehive Bedlam |
A100man |
A100man World Chat Champion
Posted: 21:21 - 24 Oct 2017 Post subject: |
DRZ4Hunned wrote: | I've decided to give JB weld a go, nothing to lose eh?
Not much I guess.
If it were me and this was purely a utility machine I would clean the buggery out of it with brake cleaner then first patch over from the outside with some bean can or ally sheet having made a good key first with a file then back fill from the inside..
I never tried drilling and tapping JB style epoxy like they say you can but I sure wouldn't attempt too much torque on the screw. ____________________ Now: A100, GT250A, XJ598, FZ750
DRZ4Hunned |
monkeyman |
DRZ4Hunned |
skatefreak |
skatefreak World Chat Champion
Posted: 09:49 - 25 Oct 2017 Post subject: |
Dropped a generic Chinese 125 lump on the genny side and it cracked from the middle all the way up.
Got a scribe and scored a V to expose clean metal and increase the surface area.
Whacked in some JB weld and it was holding fine years after |
Posted: 10:02 - 25 Oct 2017 Post subject: |
Should be noted that Allen Milliard uses aluminium solder to join the two crankcases he's bandsawed apart when he's making an inline 5 out of two kawasaki triples. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Hahadumball |
Hahadumball World Chat Champion
sickpup |
sickpup Old Timer
Islander |
Islander World Chat Champion
Hong Kong Phooey |
DRZ4Hunned |
The last post was made 6 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
