Wiring help (dirt bike)
andym
PostPosted: 17:01 - 27 Oct 2017    Post subject: Wiring help (dirt bike) Reply with quote
Today I finally managed to get a couple of hours messing around with the dirt bike and decided to have a go at getting it working off the starter. It seems someone has been messing around with it previously and forgot to put all the parts back:
https://imgur.com/FMUzCir.jpg
The starter was pulled from the hole on the top right, but there's no gear to connect it to the engine..... so, what wires would I need to connect from where to where if I just wanted to rely on the kickstart for starting and the kill switch for stopping it?
This is the current mess of wires:
https://imgur.com/XmP8qBS.jpg
monkeyman
PostPosted: 09:54 - 28 Oct 2017    Post subject: Reply with quote
The wiring looks a mess.
I would start again and wire it for keyless setup
There are few different types of CDI, 4,5 and 6 wires which is determined by how your stator is wound
What bike and year is it? Can you find a wiring diagram?
https://tops-stars.com/wp-content/uploads/2017/09/5-wire-cdi-wiring-diagram-5-pin-cdi-box-wiring-diagram-wiring-with-cdi-wiring-diagram.jpg[/url]
If you opt to rewire, make sure you get a cdi for a 4 stroke. The ignition advance curves are different
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
andym
PostPosted: 10:31 - 28 Oct 2017    Post subject: Reply with quote
It's a Skyteam St150, which I can find pictures of the bike, but not a lot else.
As for the year, I have no idea, I've checked the chassis number and there is either no record of it, it's a 2006 or 2031 model Confused
monkeyman
PostPosted: 14:50 - 28 Oct 2017    Post subject: Reply with quote
So if you want to press on with it, think your going to have to pull the flywheel, look at the connections, figure out, what's what
I think you are going to struggle tbh, getting parts etc for it, so might be worth considering it a lost cause
The last post was made 8 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 14 - Page Size: 40.48 Kb
