Anyone Got a Pneumatic/Electric Tyre changing machine?
PostPosted: 11:59 - 03 Nov 2017    Post subject: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
Fingers crossed I should end up with a decent sized garage in the new year. I'm thinking about what I want in there and I feel one of the most useful things would be a tyre changing machine. A Quick glance at ebay shows you can pick a working one up for ~£250. I find tyre changes such a ballache. working Mon-Fri means it only really leaves saturday morning free and even loose wheel it is costing £10 per wheel. I genuinely think I could make my money back on it eventually but more than that the convenience of being able to get in from work whip a wheel off change the tire and have it all back together at worst an hour is very attractive.
Currently it will take me the best part of saturday morning to get it down.
I've seen them being used and they do not look too difficult.
Let the tyre down.
Break the bead with the arm on the side
Clamp it on the turntable
Put the top arm on the rim and lever the tire over it
Spin it to remove the tyre.
Has anyone got one/used one/ have any advice about them?
There isn't any real difference between a car and a bike machine right?
PS I have no interest in changing it by hand, been there done that, nearly lost an eye Laughing
Copycat73
PostPosted: 12:03 - 03 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
the ones i`ve seen do both.. but rely on different attachments to service a variety of wheels.
caveat emptor
MCN
PostPosted: 13:22 - 03 Nov 2017    Post subject: Reply with quote
Bike and car wheel hub centre is the only major point. If you need/want to balance the wheel on a machine the bike wheel will need 'special' adaptors. That may be supplied with a balancer.
But you can easily balance with the manual ones that hold the wheel on a fake axle.
You gently spin (roll) the wheel round, let it stop, you add weight to the point that always rests at the top after two or three goes.
MCN
PostPosted: 13:30 - 03 Nov 2017    Post subject: Reply with quote
Buy bead lube (A de-fatted petroleum product).
Do not use soapy liquid. the sodium can rot the alloy rim and cause leaks.
(Sodium is the salt in washing up liquid everyone cries about when washing a car or helmet visor. Smile )
Get some rim protectors.
A valve stem remover.
A valve core remover.
And a soft crayon or blackboard chalk. (To mark the position the wheel is on the rim to negate a need to re-balance the wheel.)
PostPosted: 14:10 - 03 Nov 2017    Post subject: Reply with quote
I've got the soap stuff and other tools with my manual kit. As for balancing I just raise the front wheel, remove my calipers and balance it between the forks. Thumbs Up
Fizzer Thou
PostPosted: 16:15 - 03 Nov 2017    Post subject: Reply with quote
Have you got a compressor?
Have you got 3 phase?
Have you got the space that can be dedicated to just that one piece of equipment?
You will need a valve inserting tool.
I do my own road tyres and it takes about 35 minutes to do say a 190 rear for my R1 and about 40 minutes to more accurately balance a 120 front after fitting.
I did contemplate owning a tyre changer as I used to work for a company who dealt with them as well as other garage equipment.But to make itself cost effective I would have to do other peoples tyres as well.
Always have a 'Plan B'
PostPosted: 16:45 - 03 Nov 2017    Post subject: Reply with quote
I will have a compressor and should have space, I have seen a few single phase ones on ebay, eg.
https://www.ebay.co.uk/itm/Tyre-Machine/322855747313?hash=item4b2bb3bef1:g:RzIAAOSwhOxZ92kt
Saving money isn't the primary reason to get one it is the convenience mainly.
DrDonnyBrago
PostPosted: 17:07 - 03 Nov 2017    Post subject: Reply with quote
https://www.ebay.co.uk/itm/New-Silverline-4-Way-Tyre-Valve-Repair-Tool-for-Car-Bike-Van-tyres/272884011675?epid=1805248723&hash=item3f8927929b:g:Mm4AAOSwBLlVZjh~
I use one like that.
Cut the old valve off, push the new one in, thread that jobby on and give it a pull to seat the valve.
Do you have something more elaborate?
My equipment is fairly pikey. It's a few lengths and wedges of timber as a bead breaker, some rim protectors and tyre levers. I made a balancer that bolts to the top of axle stands. It's a few bits of box section steel, four skateboard bearings (remove the seals, wash out the grease and reassemble with machine oil for very slippery bearings), some bolts and my bike axle. Wheel weights are cheap.
In theory it takes me about 1/2 hour to remove and replace the wheel and tyre, plus about 10 mins to balance.... In reality I spend ages cleaning out calipers or whatever else I spot that needs attention whilst I am at it.
johnsmith222
PostPosted: 17:22 - 03 Nov 2017    Post subject: Reply with quote
For home use, you are probably best just using manual equipment. I change my own car and bike tyres, using different equipment for each (bike tyres are a lot easier to do with the levers I have).
My equipment for bike:
Abba bead breaker bought second hand for maybe £40
3 long tyre levers
5 or 6 rim protectors (don't need that many, but makes things easier not having to change positions)
Big bucket of tyre soap
tyre soap brush
Stanley blade for removing old valve
99 pence valve puller/core tool
£50 compressor second hand (not worth messing about with brake cleaner and lighter method, ratchet straps etc).
£40 balancing stand
equipment for car:
£35 tyre changing stand and large wooden pallet (can get them on ebay. Also has bead breaker built in).
£70 "alloy mate" bar. Sealey make them too. Stop you fucking your rims.
Wheel balancing: none. Car's a shiter so I don't bother. Depending on how much I care, I might get a bubble balancer if I can be bothered.
that stand can do up to 16" wheels in the instructions, but was also able to do my 17 inch 225/45 tyres on my saab with force. I wouldn't want to do anything more than that.
Biggest savings are on: cost of buying tyres online from the likes of oponeo, or for the car, buying good part worns from gumtree rather than relying on the pikey bastards that hide bubbles on the inside at the part worn place.
My equipment has definitely paid for itself since 2012.
Fizzer Thou
PostPosted: 17:37 - 03 Nov 2017    Post subject: Reply with quote
I bought one of these for about £1.50 from amazoom Wink
https://www.ebay.co.uk/itm/TYRE-VALVE-PULLER-INSERTING-TOOL-300MM-SHAFT-CAP-THREADS-STRONG-SWIVEL-END-PBK/201822551560?hash=item2efd8fbe08:g:P3YAAOSwax5YpvVX
Enduro Numpty
PostPosted: 19:09 - 03 Nov 2017    Post subject: Reply with quote
I've been changing my own tyres for years and the longest part of the operation is usually removing and re-fitting the wheels.
I use a Scorpion mousse changer left over from my enduro days. Basically a heavy duty, manual bead breaker that also holds wheel.
Quality tyre levers - Buzetti.
Tyre lube - helps removal and fitting
50 litre compressor - best money I've ever spent.
valve removal tool.
Static balancer and weights (rarely bother balancing rear)
I've got rim protectors but TBH I find them more bother than they're worth. I keep my bikes for a long time so the occasional scratch on the rim doesn't bother me. I've also got a tyre bar but am just as quick with levers.
Decent pressure gauge and that's about it.
From starting to remove tyre from rim to finish fitting replacement (to rim) is generally well under 10 minutes. It's all the other stuff that takes the time.
If I had a garage the size of a warehouse and too much money I'd likely buy a commercial changer but these days, in a year I probably change 6 or 8 tyres.
PostPosted: 23:10 - 03 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
I've had an air-only tyre machine (I still have it, but awaiting collection as sold to a friend I owed some favours too for a knock down price a while ago.)
I don't find it massively harder using a completely manual cheap 'machine' - and much easier to take to trackdays etc. (And people have actually tried to give me money to do their tyres at trackdays - but usually been busy enough with my own stuff.)
Does take a little longer.
Courier265
PostPosted: 00:11 - 04 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
Yep, just like the guy who does my tyres, he is a car tyre fitter but has the doo dars for motorcycle wheels. He did a great job on my Suzuki front wheel recently.
sickpup
Old Timer
PostPosted: 08:15 - 04 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
Yes I have one, a bike specific Butler Superbike. Easy to use just don't lose your fingers.
There is a big difference thats why 2nd hand car ones are cheap and bike specific ones are expensive.
The Ebay one you linked to would need adaptors for the clamps and a different demount head to be used on motorcycle wheels and even then would be likely to scratch the rims.
PostPosted: 09:24 - 04 Nov 2017    Post subject: Reply with quote
It's getting rather expensive for a completely manual solution, but if I find myself doing a good few again (only had one trackday this year), I may be tempted by one of these...
https://www.youtube.com/watch?v=T9ymwz2sMqU
Copycat73
PostPosted: 09:33 - 04 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
they charge a £10 round my way to fit to a loose wheel & dynamic wheel balance....WSB Westgate rd...
... but you have to dispose of the old tyre yourself ..
I wonder round the bike shops & cafes for an hour and job done ... frankly toolin-up is rather expensive for 1 or 2 times per year.. and the space i just don`t have..
caveat emptor
PostPosted: 10:34 - 06 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
Do you know what the differences are? I can't picture in my head how it makes a difference. I've had my tyre changed at a car place when I needed it done in an emergency. Aside from the fact they put the tyre on backwards Laughing it was fine not damage what so ever.
dodgydog
PostPosted: 11:46 - 06 Nov 2017    Post subject: Reply with quote
I have one, the Hoffman mega mount, it's bike specific, and as you would imagine It's great for bike tyres. Also it will easily cope with removing and fitting car tyres.
The only problem with it is breaking the bead on car rims, which is a real struggle for some reason.
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
sickpup
Old Timer
PostPosted: 17:50 - 06 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
PostPosted: 18:26 - 06 Nov 2017    Post subject: Re: Anyone Got a Pneumatic/Electric Tyre changing machine? Reply with quote
sickpup wrote:
But why? What is different?
The last post was made 8 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.56 - MySQL Queries: 16 - Page Size: 117.75 Kb
