Cylinders fitted with liners.
stevo as b4
PostPosted: 19:43 - 06 Nov 2017    Post subject: Cylinders fitted with liners. Reply with quote
Can we talk about cylinder liners, the pro's and cons of, especially related to if your bike/engine left the factory with a coated/plated alloy bore.
And also if you had the parts sat around to build up an engine with either a liner conversion to the OEM cylinder, or use a newly replated cylinder instead, what would you do?
Especially if your kind of going down the tuning road, trying to get more power and still have reliability.
I've been around long enough to know there's performance engines that are very highly tuned with both types of cylinder bore, but are there any stand out overwhelming reasons why one is always better than another for pushing past factory spec and performance levels.
Oh and yeah we are talking two stroke here just to be clear. Experts give me your wisdom please.
sickpup
Old Timer
PostPosted: 09:34 - 07 Nov 2017    Post subject: Reply with quote
I can't think of a single bike in the last 20-30 years that didn't have liners, became a necessity with Aluminium engines.
No doubt there are some but can't think of any.
temeluchus
PostPosted: 12:07 - 07 Nov 2017    Post subject: Reply with quote
I imagine the aftermarket use iron liners as they don't require the plating process needed for alloy cylinders, rather than iron liners actually being better.
The BMW K100 has no liners, the cylinders are just part of the block, late airheads and I think the oilheads have no liners. They're all nikasil or similar plated.
I think some of the Japanese sportsbikes in recent years have no liners, or plated aluminium liners rather than iron as well as some two stroke motors. The R6 jumps to mind for some reason.
temeluchus
PostPosted: 12:16 - 07 Nov 2017    Post subject: Reply with quote
Just checked a bunch of 2017 japanese fours and none of them had iron liners.
PostPosted: 12:22 - 07 Nov 2017    Post subject: Reply with quote
Nikasil plating means you don't need liners. Loads of two strokes had it back in the day, and I'm sure more modern engines use it too.
redeem ouzzer
PostPosted: 14:04 - 07 Nov 2017    Post subject: Reply with quote
Most modern engines use trick coatings directly onto the aluminium because liners are heavy. The drawback with coatings is when they’re damaged there’s no rebore facility and some of the newer ones can’t be replated like nikasil can.
I don’t like the idea of fitting liners into cylinders that were originally plated. There are other design considerations like rates of expansion and piston choice to consider, which are quite different between lines barrels and those originally designed as plated.
Be a REAL MAN!
Tankie
PostPosted: 15:46 - 07 Nov 2017    Post subject: Reply with quote
Plated blocks instead of cast iron liners are used because aluminium conducts heat better than a block with iron liners, as stated if a plated bore is damaged or worn out then the whole block has to be plated and repaired ( welded and re-plated ) .
monkeyman
PostPosted: 20:46 - 07 Nov 2017    Post subject: Reply with quote
Only real difference is that its going to weigh a lot more with liners, will be a lot cheaper is you blow it up though
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
Pete.
PostPosted: 20:53 - 07 Nov 2017    Post subject: Reply with quote
Nikasil plating is harder than a Moss Side bouncer. 30k miles and the honing marks still in it. No need for iron liners any more.
a.k.a 'Geri'
stevo as b4
PostPosted: 21:04 - 07 Nov 2017    Post subject: Reply with quote
Thanks everyone!
I was always an advocate of modern plated bores on high performance two strokes anyway.
The real reason I asked is that I think my KMX has been re-build with a sleeved cylinder conversion instead of a re-plate. It starts and runs well, but is apparently about 10% down on its performance figures, and we don't think the liner is helping.
I've only done) ~500 miles on a nicely run in top end, but as my plans are involving tuning a bit, its only going to get more of a barrier to performance as it gets modified.
Think I'm decided that I need to replace the top end with the factory spec set up and run a plated bore how it should have been originally.
The linered cylinder would make for a nice off road motor for green laning etc.
monkeyman
PostPosted: 21:37 - 07 Nov 2017    Post subject: Reply with quote
10% down on power?!? So 3hp lol is that using the seat of the pants dyno
If you really sure that you have problems, do yourself a favour and keep the liner. 2 stroke blow up regularly and you can probably get the liner sorted for £40 each time
mattsprattuk
PostPosted: 04:00 - 08 Nov 2017    Post subject: Reply with quote
In for the "CLEARLY I meant nikasil as it's a type of liner. I'm right and you're all idiots" reply.
Pete.
PostPosted: 07:32 - 08 Nov 2017    Post subject: Reply with quote
That would be an argument of semantics, and a poor one at that. Nikasil is a coating process not an independent liner as per the topic.
You could CALL it a lining if you like but it sure as shit ain't a liner.
a.k.a 'Geri'
stevo as b4
PostPosted: 19:42 - 08 Nov 2017    Post subject: Reply with quote
The missing performance is from a dyno run taken at the rear wheel. Before you ask it was a smooth road tyre fitted and pumped up hard too.
Oh and though it's not the case on bigger fatter bikes, on a 100kg 125, 3bhp can make a fucking big difference to performance or how it feels IMO.
mattsprattuk
PostPosted: 00:51 - 09 Nov 2017    Post subject: Reply with quote
I think you missed my point
Pete.
PostPosted: 07:10 - 09 Nov 2017    Post subject: Reply with quote
I don't think I did, you were making a pre-emptive strike at Sickpup's expected response. I thought I'd head it off at the pass.
a.k.a 'Geri'
PostPosted: 11:04 - 09 Nov 2017    Post subject: Reply with quote
I have heard that replacing nikasil plating with a steel liner can cause problems to do with heat transfer and different rates of expansion. I think it's best to use Nikasil on a nikasil bike and vice versa. This is why RGV and RS250's are a pain if you have bore scoring.
sickpup
Old Timer
PostPosted: 17:43 - 09 Nov 2017    Post subject: Reply with quote
Not had many modern engines apart so not really run into much cylinder plating.
Early plating had problems with flaking especially on two strokes round the ports and port bridges. Manufacturers found it hard to get a consistant layer over edges on the coatings.
Cars had had coatings on Almuinium since the 70's but these tended to rev lower than bike engines.
Nice to learn something new Thumbs Up
temeluchus
PostPosted: 18:38 - 09 Nov 2017    Post subject: Reply with quote
I think the BMW's were the first mass produced bikes with the coatings, but again they are relatively relaxed engines. One of the guys in the K club pulled a motor apart at 250k and you could still see the honing marks.
PostPosted: 20:05 - 09 Nov 2017    Post subject: Reply with quote
When I were a lad:
It was difficult to re-coat re-bored (two stroke) nikasil plated barrels. THAT was when you used to get inconsistent finish and thickness. However there are companies that claim to be able to do it nowadays, and I've not heard anything to the contrary.
monkeyman
PostPosted: 20:18 - 09 Nov 2017    Post subject: Reply with quote
Where does your tuner think the HP gains are going to come from by buying a new cylinder?
I'm struggling with the concept that if you have good compression that you are loosing 10% due to a steel liner
As as far as I'm concerned, In the dirt bike world the only disadvantage of a liner in the weight
What are you using the KMX for?
Pete.
PostPosted: 20:31 - 09 Nov 2017    Post subject: Reply with quote
Oh yeah because a 3mm wall thickness liner weight sooooo much more than a single clod of mud.
a.k.a 'Geri'
PostPosted: 20:43 - 09 Nov 2017    Post subject: Reply with quote
Which again I think is his point...
I think the home tuner switching between liner and nikasil and vice versa is not a good idea unless you're swapping the entire barrel for one designed to be the other way because of the aforementioned heat transfer issues.
monkeyman
PostPosted: 21:13 - 09 Nov 2017    Post subject: Reply with quote
Granted the weight issue isn't much of an issue on a dirt bike. The point I'm trying to get at is. It's rediculas spending money on a new barrel when he has a perfectly serviceable barrel
i don't think the heat transfer issue if it really exists, is a problem on dirt bikes. The barrels really don't last that long anyway in comparison to a road bike. I've had bikes with liners(previosly a niclosil barrel) and ones without and have not seen any evidence they last any longer or make any different power. What make the difference to me is that it is so much cheaper to sort a borked iron liner
The only reason I can think that you would make less power is if the ports hadn't been matched properly. Which would be problem if not done right for both methods of refinishing a borked barrel.
I'm more inclined to think the apparent loss of power is a dyno issue or there is another problem with the bike
monkeyman
PostPosted: 21:32 - 09 Nov 2017    Post subject: Reply with quote
If the top end is in good condition then the places to look are
- exhaust, is the correct expansion pipe fitted to your bike. The pipe is actually matched to the barrel.
- is your jetting correct (this is a black art on two strokes) consider the possibility your tuner may be inexperienced on two strokes
- air leaks, have your pressure tested your bottom end
- KMXs are getting on a bit, the carb and particularly the slides and needle jet can get warn and from all the vibration resulting in the jetting being thrown out
- does the KMX have a mikuni "TMX" carb? if so throw it out and get a Keihen
The last post was made 6 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.78 - MySQL Queries: 17 - Page Size: 139.69 Kb
