Keeway RKS 125 battery and oil change
harrow
PostPosted: 13:55 - 10 Nov 2017    Post subject: Keeway RKS 125 battery and oil change Reply with quote
Hello chaps,
the bike is out of warranty,
I am going to replace the starter battery, will the bike loose the time on the clock or any mileage or settings when I disconnect the old battery ?
I can lash up an additional standby battery during the change but there is added risk if I short anything out.
As for the oil change I have some fully synthetic 5w-40 oil it says on the bike to use 10w-40,
Would 5w-40 oil be too thin ?
Thanks for your help ?
Who invented a bike without a kick start ?
Smile Smile Smile
Robby
Dirty Old Man
PostPosted: 00:41 - 11 Nov 2017    Post subject: Reply with quote
You will need to reset the clock. There are no other settings to lose.
5W40 will be fine, assuming it's an appropriate bike oil. If it's a car specific oil then it could cause clutch slip - a small number of car oils have been known to do this, magnatec was always a problem.
harrow
PostPosted: 09:37 - 11 Nov 2017    Post subject: Reply with quote
R.
Thank you for that.
Regards using 5w-40 that is what I use in the car and I have about 4 litres of that.
I have some mineral oil that I use in the lawn mowers and maybe that would be a safer bet.
Also regards changing the battery I might try have a spare 12 volt battery patched across the old bike battery but it is a bit fiddly as there is not much room, not like doing that on a car.
Thank you for your reply. Smile Smile Smile
The last post was made 6 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.35 - MySQL Queries: 17 - Page Size: 36.73 Kb
