Dimerz |
Dimerz Nitrous Nuisance
Posted: 17:52 - 10 Nov 2017 Post subject: Aprillia RS125 not starting [Fixed] |
Hello, my 58 plate aprillia isnt starting, has a new battery has a new spark plug, will get another new spark plug to test it. This all started yesterday, i put in the new battery bike didnt start, so bump started it and it started but then died as i let go off the throttle i think. Couldnt figure out the issue yesterday so headed back to the bike today. We remove the spark plug , cleaned it with carb cleaner, put it in and it started but then died again because i thnk i let go of the throttle again. So then we removed the carb bowl; the fuel was clean, sprayed out the jets and it still failed to start. We tested for a spark in the spark plug but im not sure if it had a big enough spark. We put a bottle cap of petrol in the spark plug hole twice and it didnt start. Gearbox oil is low.
The solution:
Dimerz wrote: | The new vacuum fuel tap fixed it, runs much better now than before when it did run, not sluggish in the first 3 gears. |
jaffa90 |
jaffa90 World Chat Champion
Nobby the Bastard |
Dimerz |
P. |
P. Red Rocket
Dimerz |
Dimerz |
P. |
P. Red Rocket
Dimerz |
P. |
P. Red Rocket
Dimerz |
Dimerz |
Dimerz |
Stoker |
Stoker Nitrous Nuisance
Posted: 23:03 - 16 Nov 2017 Post subject: |
Only needs a tiny hole for the vacuum to not be adequate to actuate the valve enough.... It can cause problems when you can start the bike on "prime", get down the road to a junction where you are idling for a moment and it dies. especially when you are pulling out onto a roundabout.
I hate vacuum valves |
Dimerz |
Nobby the Bastard |
Dimerz |
P. |
P. Red Rocket
Dimerz |
P. |
P. Red Rocket
Dimerz |
Dimerz |
P. |
P. Red Rocket
Posted: 01:08 - 19 Nov 2017 Post subject: |
All good now but I meant the actual vacuum part where the pipe connects to, not the tank end. If when turning over you felt nothing there then a tap wouldn't fix. Glad it's working now |
The last post was made 6 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
