RickTaff |
RickTaff Nitrous Nuisance
Pete. |
Pete. Super Spammer
Posted: 00:26 - 12 Nov 2017 Post subject: |
Sure you can but it might make the engine run rough, popping on the overrun, hesitant on throttle or rough idle - or all three. Might also increase fuel consumption. ____________________ a.k.a 'Geri'
RickTaff |
Chris45 |
Chris45 Nitrous Nuisance
Pete. |
Pete. Super Spammer
Posted: 01:48 - 12 Nov 2017 Post subject: |
Popping is caused by air getting in at the leak. Oxygen in the exhaust allows any un-burnt fuel to ignite when the exhaust valve opens, which is where the pop comes from. ____________________ a.k.a 'Geri'
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 10:56 - 12 Nov 2017 Post subject: |
Whether the engine will still run.. run well enough to ride, is one questio; ext is will it continue to, or lasting damage be done to the engne... to whih the answer is 'possibly' tending to 'probably'
Whether it's LEGAL to ride with it like that is a very different question.... technically, its a defective silencing system, and riding with it knowingly defective, is one potential offence, if it causes excessive noise, another one or two, if any one is bothered to pursue you to the full extent of the law about it.
Exhaust gaskets are about a quid... if the exhaust studs aren't shagged and its the only problem you got its a ten minute fix with one spanner... so what reward to you get for ether risk? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 6 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
