Wall mounting a projector
Jayy
Mr. Ponzi
PostPosted: 19:41 - 12 Nov 2017    Post subject: Wall mounting a projector Reply with quote
About to buy a new projector and screen and need a way of mounting it to the wall, not the ceiling.
I need to mount the projector upside down too, as to get the right vertical shift, it has to be done like this.
How would you go about this? It's a big bastard as well, for scale here's a dudes hand next to it...
https://i.imgur.com/agXLmTk.png
PostPosted: 20:30 - 12 Nov 2017    Post subject: Re: Wall mounting a projector Reply with quote
Depends the type of wall - but... get appropriately strong brackets and fixings. Attach.
I've got some basic braced L brackets that take either 100kg or 200kg each - so strength there just a case of matching to your needs.
Could run them upside too if going for braced ones; then hang the projector if desired.
So just depends how your wall is - tried to put a pull up bar up for a friend using twice as many better fixings that was recommended as their walls weren't great - it still pulled out if you used the further away bar - wall seemed to be mostly mortar.
Jayy
Mr. Ponzi
PostPosted: 22:47 - 12 Nov 2017    Post subject: Re: Wall mounting a projector Reply with quote
Not sure how well the wall is going to take it but better than the ceiling for sure.
So just get some L brackets and hang the projector off them? Hmm... I thought people would suggest building some kind of shelf thing or something, I'm shit with this stuff.
What about this?
https://www.ebay.co.uk/itm/UNIVERSAL-PROJECTOR-CEILING-WALL-MOUNT-BRACKET-LCD-DLP-MONITOR-TILT-EXTENDABLE/351654873361?epid=889207606&hash=item51e0438911:g:b84AAOSwUuFWwhHq
Jayy
Mr. Ponzi
PostPosted: 23:38 - 12 Nov 2017    Post subject: Reply with quote
Found a good solution :
https://www.amazon.co.uk/Duronic-PB010XM-Telescopic-Universal-extendable/dp/B01D3PYY2S/ref=sr_1_23?ie=UTF8&qid=1510525850&sr=8-23&keywords=projector+wall+mount
Projector is 40cm long and weighs 8kg.
This mount starts at 38cm and extends to 60cm, so it's perfect and swivels / tilts, etc.
The other one I posted looks (and is) too cheap.
The last post was made 6 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 17 - Page Size: 41.54 Kb
