Rustamas |
Rustamas L Plate Warrior
Posted: 12:09 - 15 Nov 2017 Post subject: Peugeot speedfight 2 100cc Weird noise |
Hello, I have a weird noise coming out from engine and I am not sure what could be wrong... here is a link for the video, I hope someone can help me.
Thank you
https://www.youtube.com/embed/YMMIrcTPvyQ |
WD Forte |
WD Forte World Chat Champion
Rustamas |
Nobby the Bastard |
bassmastergen... |
bassmastergen... Nitrous Nuisance
Posted: 18:08 - 18 Nov 2017 Post subject: |
Rustamas wrote: | So I just took it apart, gudgeon pin is lose, it has movements up and down, I think that it should be like that and then the whole piston is really wobbly. |
If the gudgeon pin is wobbling about, I would check to see if the small end bearing has disintegrated. Top end kits for these little 2-strokes are cheap, so if there's been any damage to the piston and bore I would replace the lot. If you find that the bearing has broken up make sure there aren't any bits left in the engine.
Before you go spending any money, though, check for vertical play in the conrod - if there is any then you're going to be needing new crank bearings at the very least, and you may want to consider getting a second hand engine or, as it's a Peugeot, throwing the whole bike in the nearest skip. |
The last post was made 6 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
