| Ted |
 Ted World Chat Champion
| TaffyTDM |
 TaffyTDM Spanner Monkey
| Ted |
| NutsyUk |
 NutsyUk Nearly there...
| TaffyTDM |
| Courier265 |
 Courier265 World Chat Champion
| bamt |
 bamt World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 03:46 - 22 Nov 2017 Post subject: |
See Bike 2 Bike Communication.... where to start
I use Midland 42's.They were/are about the only hand-held CB still commonly available. They are pretty small, & pocketable; can be run off alkalines or nicad's, or fag-lighter adapter, & I have yet to have battery go flat on one, other than when daughter has left hers turned on in her hat, in the top-box over night!
At last check, they are about £120 new, with accessory pack; add around £30 for a decent PTT helmet head-set to suit. There are a couple of 'copies' on the market and latest seems to be the 'moonraker, priced about £80, typical 2nd had e-bay price of a genuine Midland. They do ted to hold value better than car-mount rigs. The old Eurosonic 'Brick' and similar offerings is practically as useful give that you really only set channel on start up, and leave the thing alone from then on! But IS bulky!
Key, though IS the headset, whether you go CB or PMR, and once wired, the difference in bulk tween a PMR & a hand-held CB is't so significant, more so is probably getting the PTT set up 'sorted'. But even a not-so great PTT down your sleeve, I find less irksome than suffering VOX with the auto transmit, clipping the first part of any transmission or dropping out when speech is quiet or squarking you when something loud passes the 'other' mic!
You can also talk to yourself or not get told off for swearing to much when a Sunday-Driver cant make up their mind which way to not indicate or the like!
As to range, its not so much the range, as the reliability. 446 is legally restricted to just 1/4w transmitter power, and on such a high frequency needs pretty much clear line of sight between radio's..
Ranges of perhaps 4 miles, at the limit of their capability are often claimed, and I will say (that, and possibly a lot more) are achievable, but only under ideal conditions..
I have had PMR 'drop-out' of range in under 1/4 mile in less than ideal conditions; eg, filtering through a set of traffic lights, & been stuck out of range, in seconds.. a niggle I have also suffered with 1w transmitter 'commercial' radio on 446Mhz, as well.
Licence-Free CB gives you 4W of transmitter power, which is rather more helpful, though still more line of site sensitive on still rather high VFH frequencies legally allocated, but not so much as 446 UHF; you can still get similar line-of-sight restrictions, but they don't come up 'quite' as quick or as often, at the lower frequency, & the higher transmitter power, stretches that 'margin' a far bit n compensation.
Practical difference is that instead of getting stumped at a set of traffic lights, and loosing comms almost before you cant hear the noise of their un-baffled end-can, you can, usually, still yell at them that your stuck at a red, maybe five junctions back!!!
'Good' PMR these days my come close to the same sort of practical reliability; but to get it you are looking at the most expensive PMR sets, probably as or more expensive than Hand-Held CB; you still need the headsets, and the PMR more likely to offer it are also more likely illegal modified or other-market sets, with 1w or even 4w transmitter powers, and even shorter dedicated battery life.
CB, still has some advantages, and certainly as far as cost, where a 'cheap' PMR is probably false economy, especially if you try ad use it with in-built VOX and mobile phone type ear-piece & mic,likely to be physically painful under a crash-hat if not more elsewhere!
| Courier265 wrote: | CB radio came and went, I would be surprised if anyone is on channel these days.. |
And that's a disadvantage!?
Actually great, not having to listen to cross-talk of other traffic or have to listen to taxi-drivers & pizza delivery persons, on 446Mhz!
| bamt wrote: | Don't the 4x4 crowd still use them? |
Yes ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| TaffyTDM |
| Ted |
| TaffyTDM |
 Posted: 12:52 - 23 Nov 2017 Post subject: |
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F132403714554
These are about a tenner overpriced but the seller has already programmed them for the standard 446 frequencies (at a much higher power level of 4w) but if you aren't teccie minded this is still cheaper than ordering the programming cable, faffing etc. They are a little naughty as out of spec but will be compatible with the off the shelf stuff and be assured zero fucks will be given if you are discreet.
They are simple to use and tough as nails. Set to low power to stretch the battery life further. If you drop it too hard, buy a new one.
Pair with this...
[url]https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F401445650641
[/url]
And you will have a decent system fit for purpose on a bike for half the price. with the change order another pair for spares whilst green laning, external magmount antennas can be found for the handsets fairly cheap.[/url] |
| Ted |
| bugeye_bob |
 bugeye_bob World Chat Champion
| TaffyTDM |
| Ted |
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
The last post was made 8 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
