YBR125 oil level
Cavallo
PostPosted: 12:59 - 01 Dec 2017    Post subject: YBR125 oil level Reply with quote
Hi Guys,
after an oil change on my 2016 ybr125, i use a liter oil as it is instructed in the user manual, but the dip stick shows that level is over the mark. i do not screw the cap just seat it with the hole. any one expericned the same thing on a ybr? Rolling Eyes
Thanks
RhynoCZ
PostPosted: 13:20 - 01 Dec 2017    Post subject: Reply with quote
Is the motorcycle level? even the slightest lean right and it'll show the oil level over the top notch.
How far above are we talking about? Did you clean the dipstick before the measurement? Did you change the oil filter as well? Oil filters hold a ceretain amount of oil in them. If you have too much oil before you even started the engine, then the filter might still be empty (fix = start the engine, let the oil circulate the system first. Then turn it off, let the oil sit and take the measurement).
arry
PostPosted: 14:08 - 01 Dec 2017    Post subject: Re: YBR125 oil level Reply with quote
Cavallo wrote:
Hi Guys,
Thanks
How much oil came out? It's difficult to get it all out so you'll probably have ~150ml sloshing about in there somewhere before you've even started to fill. This is why it's always best to stick ~80% of the required oil amount in, check and then top up gradually until the right level is achieved, rather than just relying on quantity.
But anyway, how far over the mark is it? I can't imagine that you retained a significant amount of the old oil however you did it. I doubt, therefore, that it's significantly overfilled. As such, it'll likely be absolutely fine.
arry
PostPosted: 14:09 - 01 Dec 2017    Post subject: Reply with quote
Hasn't got one mate; just a strainer.
Fizzoid
PostPosted: 14:10 - 01 Dec 2017    Post subject: Reply with quote
YBR doesn't have an oil filter, it uses an oil strainer
Certainly didn't notice the same, in fact mine took just over a litre (well, presuming Motul didn't short change me)
How exactly did you measure a litre?
johnsmith222
PostPosted: 15:35 - 01 Dec 2017    Post subject: Reply with quote
It's normal for any bike to not take the exact volume of oil required.
I don't bother measure volumes, and just go off of the dipstick.
if the bike is upright/on its centre stand, then it sounds like you have added too much oil.
You could try removing some with a syringe, if you don't want to undo the drain plug.
ThatDippyTwat
PostPosted: 17:13 - 01 Dec 2017    Post subject: Reply with quote
YBR's don't like being overfilled, makes shifting a proper arse.
A Syringe and aquarium tubing work wonders.
craigT19
Jolly Green Giant
PostPosted: 13:19 - 02 Dec 2017    Post subject: Reply with quote
If you know you only put the ltr in it just leave it be and it will be fine.
The oil capacity of 1 ltr is stated for the engine when shiny new and empty, most oil changes leave a little bit behind (or alot depending on the engine) which will change the reading.
As long as it isnt significantly over it wont cause a problem. Thumbs Up
Current bike : - 2016 MT-10
Cavallo
PostPosted: 18:14 - 02 Dec 2017    Post subject: Re: YBR125 oil level Reply with quote
arry wrote:
Cavallo wrote:
Hi Guys,
Thanks
I purchased the bike from new. The first time i checked it was over filled as well and i took out some oil as i tought it had eccessive oil. But after the first change, it is over filled by a 1 liter oil.
PostPosted: 18:32 - 02 Dec 2017    Post subject: Re: YBR125 oil level Reply with quote
Did you ensure it was level when you drained the oil? If you didn't you wouldn't have drained it all.
I recently helped someone with a CBR125 do an oil change and it swallowed up a litre without trouble and I had to add some more after.
Cavallo
PostPosted: 18:38 - 02 Dec 2017    Post subject: Re: YBR125 oil level Reply with quote
i used a syringe from the filler hole.
arry
PostPosted: 18:41 - 02 Dec 2017    Post subject: Reply with quote
Why didn't you just take the drain plug out?
Cavallo
PostPosted: 18:42 - 02 Dec 2017    Post subject: Reply with quote
i used the syringe when I removed the extra oil. At the first service, i took it the to dealer and he drained the oil from the drain plug.
PostPosted: 13:27 - 03 Dec 2017    Post subject: Reply with quote
How do you know that it only took a litre, then?
Cavallo
PostPosted: 16:16 - 03 Dec 2017    Post subject: Reply with quote
How do you know that it only took a litre, then?[/quote]
at the service i provided the oil and i watched the mechanic putting in all the oil. it was a 1 litre bottle
PostPosted: 20:17 - 03 Dec 2017    Post subject: Reply with quote
I'm calling sock.
No-one does that
Cavallo
PostPosted: 18:32 - 06 Dec 2017    Post subject: Reply with quote
I'm calling sock.
No-one does that
What? I did not understand. Sorry
Pigeon
PostPosted: 00:39 - 07 Dec 2017    Post subject: Reply with quote
And if you don't have a syringe to hand, can use the pump from a handwash dispenser. Thumbs Up
Oh wait, this is BCF. So a handwash is a thing.....nevermind.
EDIT: As others have said, its 1L from new. Plus, measurement is taken when engine has been run.
2. Start the engine, warm it up for several minutes, and then turn it off.
3. Wait a few minutes until the oil set-tles, remove the oil filler cap, wipe the dipstick clean, insert it back into the oil filler hole (without screwing it in), and then remove it again to check the oil level.
Howling Terror
PostPosted: 00:40 - 07 Dec 2017    Post subject: Reply with quote
^^^With the granules when you get to my age.
YBR Ric
PostPosted: 13:43 - 27 Dec 2017    Post subject: Reply with quote
You'll remove a different amount of oil dependent on if it's just been drained on the centre stand, on the side stand or if drained on the side stand then pushed upright and leant back on the side stand again.
Continue to check the oil level on the dipstick with it resting on the filler hole - not screwed in as you've already done.
The last post was made 6 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.95 - MySQL Queries: 17 - Page Size: 113.09 Kb
