Rubber Front Wheel Nut Cap *TRYNA SOURCE*
thornnomad
PostPosted: 09:58 - 03 Dec 2017    Post subject: Rubber Front Wheel Nut Cap *TRYNA SOURCE* Reply with quote
Anyone know where you can get hold of one of these from?
Its the Black rubber cap that goes over your front wheel nut.
for a YBR custom 125. So a YBR 125 one would probably do the trick also - can't source one from anywhere.
Image shows what I'm on about, just incase your thinking 'eh??'
Cheers.
ThatDippyTwat
PostPosted: 10:02 - 03 Dec 2017    Post subject: Reply with quote
Part number 13 - Cap. looks like it's in stock.
https://www.fowlersparts.co.uk/parts/4217095/yb125spd-ybr125-27s1-2008-060-a/front-wheel
thornnomad
PostPosted: 10:20 - 03 Dec 2017    Post subject: Reply with quote
nearly £8!!! farking 'ell - I begrudge paying even a quid for somerts that costs next to duck all to make. Daylight wobbery!
and thankyou for the info - much appreciated.
*Just had a squizz at megazip - american site sell it for $6.67 so equiv of £4.95, mind you p&P would probably be a bit 5hite*
grr666
PostPosted: 10:23 - 03 Dec 2017    Post subject: Reply with quote
What size is the nut? 17mm?
thornnomad
PostPosted: 10:32 - 03 Dec 2017    Post subject: Reply with quote
I'll have to go out & have a cheeky measure grr666 - so I can't give you that info unfortunately as of right now - but yeah, good thinking, find somerts cheap that does the same job, probably off another bike with the same nut size.
EDIT: *It's 17mm*
grr666
PostPosted: 10:33 - 03 Dec 2017    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Silicone-Bolt-Head-Hexagonal-Nut-Covers-Cap-Protector-Car-Wheel-Valve-Stem-Cover/322573643125?hash=item4b1ae32d75:g:zRQAAOSw6ShZVnTQ
I have these on my wheelnuts on the car.
thornnomad
PostPosted: 10:41 - 03 Dec 2017    Post subject: Reply with quote
There's a chunkyish washer underneath the nut which sticks out a bit, hence the outer brim of the cap which covers that washer. Guess stops road crud getting in all of it.
Good ebay spot! cheers for that.
doggone
PostPosted: 10:47 - 03 Dec 2017    Post subject: Reply with quote
What's the purpose of it anyway - trap damp and salt behind?
I'd just make sure threads have a bit of grease when tightening it up and throw it away most likely.
Ideally you'd do at least visual regular check that nothing is working loose, especially if anything has been taken apart recently for maintenance.
thornnomad
PostPosted: 11:01 - 03 Dec 2017    Post subject: Reply with quote
I guess if the cap is flush then prob creates some sort of seal against damp n salt getting in / on. Plus I guess if you clonk it on somerts then the rubber acts like a really rubbish somewhat ineffective but better than nothing barrier against scratches n the like.
Yeah bit of grease & I'll find something cheaper to do the trick - £8 is taking the pish, I'll only probably go lose 'em again anyway.
Copycat73
PostPosted: 11:17 - 03 Dec 2017    Post subject: Reply with quote
if you is expectin cheap parts with motorbikes your in the wrong passtime / mode of transport..
caveat emptor
thornnomad
PostPosted: 11:30 - 03 Dec 2017    Post subject: Reply with quote
I hear you.
Although when its a poxy bit of rubber which costs nearly nowt to make, selling for nearly an Ayrton Senna - I'm gonna whinge.
And if I can get somerts to do the same thing for a whole lot less then I'm going to do that also.
Unfortunately I wasn't born with a silver spoon in my mouth, a plum in my accent & / or bottomless pockets.
Copycat73
PostPosted: 12:54 - 03 Dec 2017    Post subject: Reply with quote
and you were not given a Dictionary as a christening present either ....
caveat emptor
thornnomad
PostPosted: 13:14 - 03 Dec 2017    Post subject: Reply with quote
You're not wrong.... but then you're not right either.
smegballs
PostPosted: 13:49 - 03 Dec 2017    Post subject: Reply with quote
The last post was made 6 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 17 - Page Size: 83.93 Kb
