Kawasaki ER-5 - oil site glass misting up during winter use
daws0n
PostPosted: 19:21 - 06 Dec 2017    Post subject: Kawasaki ER-5 - oil site glass misting up during winter use Reply with quote
I bought myself an ER-5 recently - regulator issue aside it's been a reliable workhorse so far. It had a full service mid 2015 and it's only clocked up a 2500 miles since, but as 18 months have passed now I figure it's time to give it an oil and filter change.
I've noticed that over the past few weeks the site glass has gotten progressively cloudy. So much so, that I could barely see the oil level behind it. Research online suggested this is due to my short daily commutes and cold weather, not allowing the engine to get hot enough and causing condensation... This evening I put that to the test and took the filler cap off for half an hour after getting home. Lots of steam escaped and as hoped, the glass is much clearer now - a little emulsification remains but I should be able to get a good reading when I change the oil over the weekend.
I don't have have a garage and keep the bike outside, so am a little of keeping the filler cap off regularly while exposed to the elements - are there any further steps I can take to prevent this from happening over the cold winter months?
iooi
PostPosted: 19:38 - 06 Dec 2017    Post subject: Re: Kawasaki ER-5 - oil site glass misting up during winter Reply with quote
Take the bike for a good long run to burn the moisture off. But even then if you are only doing short trips it will return....
Chris45
PostPosted: 19:56 - 06 Dec 2017    Post subject: Reply with quote
Agree with above. Wouldn't worry about it too much at the moment and no need to keep taking off the oil filler cap... heat out, cool moist air being drawn in! These engines take about 10 miles to warm up properly, so if you're doing less than that to/from work, there's not much you can do other than buy a CG125 Wink
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
daws0n
PostPosted: 20:23 - 06 Dec 2017    Post subject: Reply with quote
I took a detour to work the other day and did a brisk 25 miles.... That didn't touch it, so glad that taking the filler cap off has improved things considerably. I'm guessing it will need a good 75+ mile trip to clear up proper?
My daily commute is 8 miles each way and only 30/40mph, so it does need a good run in all fairness... I'll take it on the motorway on the weekend and will do so more often - it's easy not to when I use the bike all week but I doubt pottering about in 3rd/4th all the time will do it much good long term.
I've already bought some 10W40 s/s oil ready for the job. No idea on the brand but my local motorbike garage use it every day and sell it straight from the drum. I was thinking it's best to do another change ready for summer in a few months time so will chuck in some good stuff then.
daws0n
PostPosted: 20:28 - 06 Dec 2017    Post subject: Reply with quote
I do rather miss my 125 actually Chris - ideal for this kind of riding really. Got rid of my little XV years ago, it was a tidy little runner and I missed the fuel economy when I changed over to an XJR. This ER-5 cheap as chips to run in comparison, but shame about the brakes though. Going from 3 discs and brembo calipers to 1 disc and a drum takes some getting used to!
Chris45
PostPosted: 21:28 - 06 Dec 2017    Post subject: Reply with quote
My first ever bike back in 1979! Still miss it's free revving engine and 120 mpg even when pushed to the limit. The ER and Gpz 500's all have poor brakes, especially mine with the rear disc . The ER is a tidy street cruiser (slightly detuned from the GPz) but it still needs regular exercise Smile Leave the oil change till the Spring and don't worry to much about the misting issue, it would take some considerable time before it was an issue. Most important thing is you use your bike regular. Cheers.
PostPosted: 22:06 - 06 Dec 2017    Post subject: Reply with quote
You can vent the oil filler cap by drilling a tiny (like 2mm) hole into it from the side then drilling another, slightly larger hole up from the inside (not al the way through) to meet it at 90 degrees. Seen it done on other bikes, not an ER5
Obviously, you risk water getting in too but it should be minimal, especially if you position the vent hole facing backwards. If it causes a problem with either water gettng in or oil mist getting out, simply melt the end of the hole shut again with a soldering iron..
The last post was made 6 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 17 - Page Size: 56.24 Kb
