Dumb carb question
andym
PostPosted: 23:40 - 07 Dec 2017    Post subject: Dumb carb question Reply with quote
TL;DR: if the fuel tap outlet is below the carb inlet by 4-5cm.... would it cause fueling issues at higher revs?
I haven't had the chance to do any testing to find out for myself, so figured I would ask instead.
The last time I worked on the dirt bike I removed the starter motor so I could get access to the mixture screw on the carb, while the engine was running (stupid place to put it IMO), going from 1 turn out to 3 turns out (using 1/4 turns each time), the exhaust went from clear to smoky.... although not a lot of difference in the idle strangely. The one thing that remained though was the lack of getting past half throttle before it coughed, spluttered and a lot of the time died.
The carb has been cleaned numerous times, so I know that shouldn't be the problem.... so now I'm thinking it may be the fuel line that could be the issue. The fuel tap outlet sits below the carb inlet, add to that the 1-2cm drop from the tank, then 6-7cm (over the frame otherwise the hose kinks) rise then 1-2cm drop into the top of the carb... would the engine be creating enough of a vacuum to draw fuel through the fuel line?
I know I could easily test this by removing the tank and holding it above the carb level.... but at the moment it's dark when I fall out of bed and dark when I get home.
Pete.
PostPosted: 00:35 - 08 Dec 2017    Post subject: Reply with quote
The outlet height is largely irrelevant, the fuel level in the tank is what provides the flow to the carb. If the level of the fuel in the tank falls down to near the float bowl fuel level then no more fuel will flow to the bowl. The nearer the two levels are to each other the more the fuelling will be affected when demand is high.
If it has an inline filter, check that (as in remove it).
a.k.a 'Geri'
PostPosted: 00:40 - 08 Dec 2017    Post subject: Reply with quote
^ What he said.
If the top of the float chamber is below the bottom of the tank (not the tap) then so long as the tank has fuel, the carb will.
PostPosted: 10:18 - 08 Dec 2017    Post subject: Reply with quote
Bikes which have a fuel level below the float height have fuel pumps. Usually electrical these days but mechanical ones do exist.
These are simple to fit but will show up any inadequecies in your needle valve.
The last post was made 6 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 17 - Page Size: 42.4 Kb
