Help passing the MSVA / questions on getting UK plates
b0x3r B0y
PostPosted: 14:49 - 10 Dec 2017    Post subject: Help passing the MSVA / questions on getting UK plates Reply with quote
Hi,
I have a non-EU bike a Honda ACE 125 that I would like to put UK (registration) plates on - by successfully completing the MSVA (The DVLA testing the bike to make it safe for UK road). I have read the MSVA Inspection Manual and think /hope I can make the necessary changes to the bike for it to pass. However, I have some questions that I am hoping people might be able to answer:
FYI – the bike is a Category B (motorcycles with a cylinder capacity not exceeding 125cc and a maximum power output not exceeding 11kW)
Section 17 (Radio Interference) states that a bike will fail if “the HT ignition system is not fitted with radio interference suppression equipment”. What is radio interference suppression equipment and how do I know if my bike is fitted with it?
Section 8 (External Projections) states that “the rear edge of any filler cap located on the upper surface of the fuel tank should not protrude more than 15mm about the surface”. AKA, the fuel cap cannot stick up above the tank more than 15mm. My cap does. Is there any way I can make the cap sit lower in the tank/other solution ideas?
Section 6 (Lighting & Signalling). My indicators can only be used one at a time when the bike is on. However, to pass the MSVA, both need to be able to work at the same time (or flash alternatively) when the bike is off. Any ideas how I can do this?
And, to increase the brightness of my headlight, can I just put in a more powerful bulb? Or is brightness dependant on battery power? And, if I change the battery, would this allow me to use the lights when the bike is off (or is that down to wiring within the bike)?
Also, does anyone know if normal (i.e. production) bikes have to have the registration plate lit up and also have fog or parking lights (that can work when the power if off)?
Finally on lighting, what are non-triangular type rear and side retro-reflectors?
Section 23 (Engine Power Restriction Information Plate) refers to all bikes (manufactured after 2003) having “details of the restrictions displayed on a plate (at least 60mm x 40mm) attached to the vehicle by the manufacturer and marked with the manufactures name, the category of vehicle and number of teeth on the drive and driven sprockets)". I can’t seem to find this on my bike. Does this have to be one plate or can the information be shown throughout the bike? Does Honda do this? If so, where is it located?
Section 15 (Brakes) states the bike needs a parking brake. Can sticking the bike in first gear count as a parking brake?
Finally, section 15 (tyres) goes into detail on tyre markings (specifically that the tyre is moulded to permanently display “E”, “JIS” [Japan] or DOT [USA]). My tyres don’t have any of these markings, they were made in China. Am I right to assume they don’t have a hope in hells chance of passing?
Appreciate there is a lot of questions here. Any help would be great.
Thanks
PostPosted: 15:01 - 10 Dec 2017    Post subject: Reply with quote
I think it would be cheaper and easier to buy a UK spec bike. Especially as the ACE 125 doesn't seem to be anything special.
The MSVA is very difficult to pass, and is designed for specials. Imported bikes with protruding fuel caps etc... You might be out of luck.
I'm not aware of the rule requiring both indicators to flash on bikes, similarly I'm not aware that bikes need a parking brake. These sound like car rules, although it is possible the MSVA enforces these rules on a bike by assuming you can leave it in gear, and manually alternately flash the indicators... Who knows? To assume the DVLA know what they are doing is probably a mistake.
Honestly you'd be best off spending £1500 on a second hand CBF125, despite their well known rust issues etc.
PostPosted: 16:42 - 10 Dec 2017    Post subject: Re: Help passing the MSVA / questions on getting UK plates Reply with quote
Either a resistor in the plug cap (most already have one) or an NGK sparkplug with R in the part number.
Fit a different tank or cap for the test.
I think it means both at the same time on either side of the bike. So both left ones need to work at the same time or alternately or both right ones.
Depends on your charging system but if it's a small honda where the lights only work with the engine running then it has AC lighting and the answer is no to all three questions. I don't think brightness is part of the SVA test though, just position and beam pattern.
Reg plate yes, needs a white light. Can be as simple as a small hole or clear part in the taillight lens if it's located above the plate. Otherwise a single, white LED will do the trick.
No to fogs. No to parking lights.
Reflectors. A red one at the back (often part of the taillight lens). An orange one each side. Not triangular in shape. You can use pushbike ones or you get sticky backed ones (but not retroreflective tape). ACE125 has them as standard.
Pass.
I'm pretty sure this is just for trikes.
They'll need an E mark. Frankly, you also WANT them to be. Ungraded Chinese tyres. Nope! Change them.
P.
PostPosted: 09:24 - 11 Dec 2017    Post subject: Reply with quote
I'm with MarJay, but I'd also just find a CG125 VIN/v5 and hacknslash.
PostPosted: 00:41 - 12 Dec 2017    Post subject: Reply with quote
Great advice from Stink..
I SVA'd a chink monkey bike once and it failed on the minimum radius of the leading edge of th front mudguard - yes really.. I.e it was too 'sharp'. The guy there told me to glue some split plastic pipe on it as trim - they were pretty helpful.. Apart from the fact that they demanded to see the mirrors which I hadn't bothered to take with me (not an MOT item so not important I figured) - WRONG. They wanted to see they were CE marked. I suggested I could call in with just the mirrors buy no they wanted to see them attached to the bike - so meant a return trip in a borrowed van ..
.. which was nice.
hmmmnz
PostPosted: 18:05 - 14 Dec 2017    Post subject: Reply with quote
i did it my my us import triumph tiger 1050 "naked"
was actually a breeze,
the fact they make a uk model of the same bike pretty much means it'll pass.
ignore the radio emmision stuff, they dont test it.
the biggest thing is pointy bits, mirror size, exhaust noise,
everything else its just like a regular mot
the humans are dead
I kick arse for the lord
The last post was made 6 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 17 - Page Size: 59.11 Kb
