Rider of the Youth didn't check his oil level
TheFlyingEngl...
PostPosted: 17:28 - 15 Dec 2017    Post subject: Rider of the Youth didn't check his oil level Reply with quote
Right so I might be in quite a bit of trouble with the old L1 ZXR 400.
It's been the best bike I've ever bought mechanically, I've had it for a 2 months and I got it with 46k miles, I've now done up to 52k. As I've been ill and she has been sat for a week I haven't reminded myself to do any checks on the bike, in which I haven't even checked my oil level.
I rode 54 miles today, from speeds up to 60-110mph. With revs up to 16,000 (Raised rev limiter). The bike only went above half on the temperature gauge once and kept low due to high cold winds.
I had music on so I couldn't really hear anything until I was on the final 3 miles of my journey back home, and I heard a loud noise coming from the engine, so I went home and I got the good older brother to come out to check for me and all you could smell is the bike having no oil in it, so he poured 2.5 liters of oil into the engine, it only went halfway on the spyglass but there's no min-max level so I'll see if it needs more.
But I went for another ride to see if I might've saved it, it's lost no back-pressure, seems to run a lot nicer (Obviously) but there is loud ticking noise that is now coming from the engine, it gets faster when I rev up higher / going faster. So the question is; have I royally destroyed my pocketrocket?
craigT19
Jolly Green Giant
PostPosted: 17:52 - 15 Dec 2017    Post subject: Reply with quote
Honestly probably done a fair bit of damage but destroyed may be abit harsh as usually in that situation they just dont run.
Assuming your not leaving a smoke screen behind you your rings and pistons have probably survived so the ticking/nocking is likely to be summin along the lines of worn crank shells, big or small end bearings, cam guides or a combination of all of them. That could explain why it gets loader and faster as the rpm goes up because you have excessive play in there.
Does the bike vibrate more than before? especially through hard points like the pegs? and test for the noise with the bike in neutral because if the noise goes away you know its the gearbox not the engine, but if it stays you know its the engine and not the gearbox.
Current bike : - 2016 MT-10
TheFlyingEngl...
PostPosted: 17:54 - 15 Dec 2017    Post subject: Reply with quote
That's true, no It's all fine for smoke.
Honestly no, just the absurd ticking noise
RhynoCZ
PostPosted: 17:58 - 15 Dec 2017    Post subject: Reply with quote
The first thing to suffer tends to be the head. I'm going to recommend taking the valve cover off and having a look inside. As you're in there, check the timing chain tension.
If the engine ran dry, there was probably no lubrication to the camshafts, which accelerated the wear. Engine head damage might be even the source of your ticking noise.
craigT19
Jolly Green Giant
PostPosted: 18:00 - 15 Dec 2017    Post subject: Reply with quote
Well dont beat your self up as they say shit happens and were all young and forgetful at some point Very Happy
Heres one i made earlier Laughing ran out of oil and created a speed hole!
*took the pic out because it was massive on my phone
Do the neutral test i mention in my first post (edited it after you read it) but there is a fair chance you have just put a load of wear on the engine before its time and it will quite happily tick away for the rest of its days... as long as you keep oil in it Smile.[/i]
RhynoCZ
PostPosted: 18:06 - 15 Dec 2017    Post subject: Reply with quote
https://i.imgur.com/Gar4LQT.jpg
Fazer? Is that you? Shocked
TheFlyingEngl...
PostPosted: 18:08 - 15 Dec 2017    Post subject: Reply with quote
Ah hold the phone, I just read up on your edit. I believe it stops ticking when I put it in neutral, and I've had a few problems with the gearbox with it slipping out of gear every now and then, but the clutch also rattles now until you squeeze the lever.
doggone
PostPosted: 18:18 - 15 Dec 2017    Post subject: Reply with quote
Where has the oil gone in the week you didn't check it, Rolling Eyes
Usually there is enough to stave off disaster even when well below the sight glass unless it somehow mostly shot out while running.
andyscooter
PostPosted: 18:19 - 15 Dec 2017    Post subject: Reply with quote
7000 miles in two months
where the fuck have you been riding Shocked
TheFlyingEngl...
PostPosted: 18:33 - 15 Dec 2017    Post subject: Reply with quote
I've honestly never really noticed it, who knows
TheFlyingEngl...
Laps and laps and laps of Somerset xD
Kawasaki Jimbo
PostPosted: 22:22 - 15 Dec 2017    Post subject: Reply with quote
I believe the oil light would indicate low pressure, but you haven't mentioned any warning. A vehicle will run fine with a surprisingly low oil level.
This would be the "150mph race-tuned" bike -
CaNsA wrote:
Racers remove the limiter...
This can also be done to road bikes, but pointless due to the lump needing to be rebuilt every 3months.
Edit: Explain the title, "Rider of the Youth."
RhynoCZ
PostPosted: 22:28 - 15 Dec 2017    Post subject: Reply with quote
He also didn't mention any dead bulbs in his cluster, nor faulty oil pressure sensor, wiring...
It's an old motorcycle, many lazy people fix issues with just removing the check light bulbs.
PostPosted: 22:45 - 15 Dec 2017    Post subject: Re: Rider of the Youth didn't check his oil level Reply with quote
Was it on the side stand when you checked or was it upright?
Kawasaki Jimbo
PostPosted: 22:47 - 15 Dec 2017    Post subject: Reply with quote
Do they really though? That would be thick, and accessing those lights on a faired bike isn't easy anyway.
TheFlyingEngl...
PostPosted: 23:37 - 15 Dec 2017    Post subject: Reply with quote
The oil light turns on when you switch on the ignition and then goes off. It might just be my gearbox then but the noise is coming from the top of the engine.
And the Rider of the Youth is just an indication that I'm a young rider.
RhynoCZ
PostPosted: 00:51 - 16 Dec 2017    Post subject: Reply with quote
I've been buying second hand motorcycles and cars, quite frequently, for at least 10 years now and I've seen and heard things, that really made me scratch my head.
Just to give you an idea: missing bulbs and fuses, things that were disconnected for some reason and people acting stupid and/or just plain lying about all sort of things.
I'm not saying OP did it. Checking the low oil pressure warning lamp is simple enough.
RhynoCZ
PostPosted: 00:52 - 16 Dec 2017    Post subject: Reply with quote
Good, if you mean it goes off when you start the engine.
Check the head, valve cover off.
redeem ouzzer
PostPosted: 01:17 - 16 Dec 2017    Post subject: Reply with quote
It’s scrap and op is a fucking dickhead.
Although if it really is revving to 16k I’m surprised it hasn’t chucked a rod.
Be a REAL MAN!
RhynoCZ
PostPosted: 01:29 - 16 Dec 2017    Post subject: Reply with quote
This got me thinking, OP have you checked the airbox yet? When I had the CB-1 with short final drive gear ratio, I was reving it high a lot and it did spit some oil into the airbox, not that it would be much of a concern but it was noticeable.
Although, this only if the breather hoses are connected to the airbox properly.
PostPosted: 13:00 - 16 Dec 2017    Post subject: Re: Rider of the Youth didn't check his oil level Reply with quote
Copycat73
PostPosted: 13:22 - 16 Dec 2017    Post subject: Reply with quote
every kawasaki i`ve owned/ ran used oil..
iirc.. was told it seeps up between the liner and the block .. to be burnt in the combustion chamber ...
no doubt i will be corrected on this .. Rolling Eyes
probably will the next time he does it ..
and OP.. start lookin on evil-bay for a replacement engine or bike The world's smallest violin player, just for you!
caveat emptor
B0ndy
PostPosted: 14:05 - 16 Dec 2017    Post subject: Reply with quote
Another ZXR400 engine destroyed, not really surprising you can't pick a half decent one - the A2 riders have destroyed them all.
You complete donkey, make sure you never do this again.
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H
redeem ouzzer
PostPosted: 14:20 - 16 Dec 2017    Post subject: Reply with quote
I don’t believe it suddenly started supping oil. I bet OP never checked it so would have had zero clues it burnt a bit until it made horrible noises and smelt like a foundry.
Be a REAL MAN!
RhynoCZ
PostPosted: 16:24 - 16 Dec 2017    Post subject: Reply with quote
This +1
I owned 2 Kawasaki motorcycles, the GPz required 1L of oil between the annual oil changes (to stay above the MIN notch) and the ZX7R burned some but didn't have to top it up between the oil changes, although that's only because you don't really have to rev a 100kW engine that much to get it going.
A smaller and very fast revving 20+ years old engine from Kawasaki is a completely different story. Especially if ridden without any mechanical sympathy. Thumbs Up
It's not just Kawasaki, though.
The last post was made 6 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 17 - Page Size: 143.4 Kb
