PDF writers
Andy_Pagin
PostPosted: 17:30 - 19 Dec 2017    Post subject: PDF writers Reply with quote
Anyone got experience of using the Po-Do-Fo library? Particularly in a MinGW GCC project.
RhynoCZ
PostPosted: 17:43 - 19 Dec 2017    Post subject: Reply with quote
PDF writers you say? I have never used one, always did all my work in libreoffice or MS word (the same result) and then convert it into the PDF format.
It's been a while since I've used a converter, but I never had to pay for any, all legit copies.
Andy_Pagin
PostPosted: 17:52 - 19 Dec 2017    Post subject: Reply with quote
I mean as in a library I can statically link into a c++ project to generate a pdf document from scratch.
I've used the PDFWriter library in the past with Visual C++ but getting it to build with MinGW GCC is proving to be a nightmare.
Pete.
PostPosted: 20:55 - 19 Dec 2017    Post subject: Reply with quote
I use pdfill to print anything to pdf. If it's an office document I use File - save as but pdfill works for everything else.
a.k.a 'Geri'
barrkel
PostPosted: 23:24 - 19 Dec 2017    Post subject: Reply with quote
Out of curiosity, I checked out https://github.com/galkahana/PDF-Writer.git ran `cmake . && make` and it appeared to build locally fine using Cygwin gcc.
I'd try with msys2 to get a MinGW build together. I don't use msys2 and amn't about to install it to try.
Andy_Pagin
PostPosted: 01:29 - 20 Dec 2017    Post subject: Reply with quote
I'd try with msysgit to get a MinGW build together. I don't use msysgit and amn't about to install it to try.
I'll take a look at that, I was using a version I downloaded years ago from elsewhere.
The last post was made 6 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 17 - Page Size: 51.62 Kb
