Broganhogan |
Broganhogan L Plate Warrior
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 21:26 - 19 Dec 2017 Post subject: |
Could be the side stand cutout switch, if there's a loose connection you'll get stuttering if the vibes hit right.
If not, is it fuel injected or carburettor? If you don't know, what year is it? ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Broganhogan |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 17:48 - 20 Dec 2017 Post subject: Re: Bike engine major stutter when accelerating |
Broganhogan wrote: | If anyone's has any ideas as to what the problem may be it would be a lifesaver to know. |
At a guess, I would chance at 'User Error'. but we aren't clairvoyant you know!
Shaggy asked if it was carb or FI & what 'model' year it was.. so Oh-Kay, it's FI... what year it came into your possession, doesn't really help narrow down the model year very much! Help us help you here, mate!
Stuttering sounds like a fueling issue.. could be anything from there being crud in the fuel-tank, through the injector being gummed up, with potential electrical and mechanical maladies in between, such as the ECU not getting signal from the lambda sensor in the exhaust, or the throttle position sensor being dirty or the ECU tripping to 'limp-home' mode for any of a variety of other reasons.
A-N-D could be utterly un-carburetion related.... the valve clearances could be out.... when was it last properly serviced and had its tappets adjusted?
What state is the exhaust in?Is it leaking or blowng by the exhaust port? Is there a hole in the exhaust pipe any-where? Has the exhaust pipe got a big dent in it, or anything?
Might not be caused by the engine; you could have a siezed link in the chain, or an oval back brake drum, and are inadvertently slightly 'riding' the rear brake, or the brake's binding. or 'something' like that.
Start at the top, and base line the issues for further diagnostics; gt the haynes manual, work through the entire list of recommended user service procedures.
-Drain the petrol tank and clean or replace the fuel filter.
-Check/clean/replace the air-filter
-Get a new spark-plug
-Check adjust the tappet clerances
-Check adjust the cam-chain tension
-Change the engine oil
- clean drive chain - check state o sprockets.. adjust drive chain tension & lube chain, replace C&S if necessary
- Check throttle cable adjustment, clean/lube
- Check clutch cable adjustment, clean lube
- etc etc etc anything else on the list in the manual
THAT lot 'done' there's a very very good chance that the 'problem' will simply disappear.. If NOT... then you will have eliminated all the 'silly' questions before you begin, of what it cant be, so by process of elimination, IF problem persists, YOU stand a much better chance of finding the cause, and fixing it, than we do, by voodoo.. like I said, unfortunately we aren't clairvoyant! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
MCN |
MCN Super Spammer
Chris45 |
Chris45 Nitrous Nuisance
Courier265 |
Courier265 World Chat Champion
AldridgePrior |
AldridgePrior Banned
bikenut |
bikenut World Chat Champion
The last post was made 6 years, 119 days ago. Instead of replying here, would creating a new thread be more useful? |
