| Author |
| adengtg |
 adengtg Scooby Slapper
| Back to top |
| arry |
 arry Super Spammer
| Back to top |
| adengtg |
| Back to top |
| arry |
 arry Super Spammer
 Posted: 12:30 - 22 Dec 2017 Post subject: |
Sorry yes, they are attached. Just edited my post . |
| Back to top |
| adengtg |
| Back to top |
| trevor saxe-coburg-gotha |
 Posted: 13:44 - 22 Dec 2017 Post subject: |
ace ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| Back to top |
| M.C |
 M.C Super Spammer
 Posted: 14:23 - 22 Dec 2017 Post subject: |
Fuel injection... like going black  |
| Back to top |
| adengtg |
| Back to top |
| M.C |
 M.C Super Spammer
 Posted: 14:46 - 22 Dec 2017 Post subject: |
Starting procedure for my XR:
- Warm Summers day: start and ride (no choke)
- a bit nippy (so most of Summer/Autumn/Spring): partial choke and a short period warming up
- Winters day: coax the f'ing thing into life, keep it running with short bursts of throttle, too much and it stalls Eventually it's warm enough to actually let you ride it.
Starting procedure for my FI bikes:
- Most of the year: hit starter... ride off straight away.
- Really cold weather: occasionally it starts on the button second time... then I ride off straight away.
I appreciate some carb' bikes are better, but they all need warming up (unless you ride with the choke on ). |
| Back to top |
| thx1138 |
 thx1138 World Chat Champion
 Posted: 21:59 - 30 Dec 2017 Post subject: |
starting procedure for my Beta
turn the choke on, turn the fuel on, bounce the bike up and down a bit, hit the starter
if that doesn't work, put it in gear and bump it back and forth, then put it in neutral then start it
leave choke on for about 1 minute, killing everything with clouds of smoke, then take choke off, then either ride off with it a bit sketchy, or idle for another minute and ride off
starting procedure for my Honda
hit starter, ride off  |
| Back to top |
| NJD |
 NJD World Chat Champion
 Posted: 23:14 - 30 Dec 2017 Post subject: |
w0t arry saiz, yo.
I used to have to turn the tap off on my Arrow after every ride, forget why but was important. Thinking that might be the same.
Check the idol speed once you get to go out -- weather permitting -- and ensure is between 1,000-1,500 rpm (based on Arrow). Just because it's cold and it's an easy thing to adjust.
Cheap as chips to run: 1 litre of oil, one spark plug and a battery and air filter that are no doubt under the side panels and seat (oh, stick some red rubber grease on the lugs of the side panels whenever you next take them off so they don't freeze up and snap because cheap plastic -- pot of red rubber from ebay, you'll need it when it comes to servicing brakes also).
Get yourself a 13 mm chain also. You'll want to chain it up at all times because yout dem theft-magnet even if slow. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| Back to top |
| adengtg |
| Back to top |
| NJD |
| Back to top |
| M.C |
 M.C Super Spammer
| Back to top |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Back to top |
There is a gap of 5 years, 289 days between these two posts... |
| alamn2 |
 alamn2 L Plate Warrior
| Back to top |
| that_impulse_guy |
 that_impulse_guy Scooby Slapper
 Posted: 12:42 - 20 Oct 2023 Post subject: |
it'll be a fuel injected bike by 2021 era , so wont have a on/off fuel tap, it will have a fuel pump that sorts all this out by itself.
also, thread necro. ugh. ____________________ Gone: Yamaha DT50lc, Suzuki DR500, Suzuki A100, Kawasaki z250ltd, RD350YPVS, Suzuki DR Big, Kawasaki AR125, Kawasaki KMX200, Suzuki GS1000S, Katana 1100, GS550M, Suzuki RGV250
Now: Suzuki GSX400X, Suzuki RF900R, NS400R |
| Back to top |
| alamn2 |
| Back to top |
The last post was made 2 years, 127 days ago. Instead of replying here, would creating a new thread be more useful? |
