Need advice on Honda Vfr400 nc30
Malik Noman
PostPosted: 13:44 - 21 Dec 2017    Post subject: Need advice on Honda Vfr400 nc30 Reply with quote
i bought my lifes first motorbike, a vfr 400r nc30, the engine is not in good shape, the cam shaft is making noises and the bike heats up in traffic where i down shift and upshift the gears alot. Now i need suggestion , what to do with the engine... will repairing cam shaft help because the previous owner did repair the cam shaft and its faulty again, or should i get a new engine/used engine..where can i buy it from? someone suggested me to buy a used cbr 400 engine coz its in line engine and he said its better then the v4 stock engine.. please help guys!!!!
PostPosted: 16:11 - 21 Dec 2017    Post subject: Reply with quote
A cbr engine won't fit.
You'll want to get rid, its a money pit.
redeem ouzzer
PostPosted: 18:43 - 21 Dec 2017    Post subject: Reply with quote
These aren’t really repairable. As complete engines are getting rare unless the rest is mint I’d be doing as Paddy suggests and getting rid.
Be a REAL MAN!
RhynoCZ
PostPosted: 18:54 - 21 Dec 2017    Post subject: Reply with quote
Cam shafts may be resurfaced, if excesive wear is the problem.
EDIT: Apparently not, Paddy says. Thinking
Heat issues, there might be none. These 400cc pocket rockets from Honda run hot. It's when the needle of the temp gauge gets to the red zone you have a real problem.
You won't be able to fit a CBR engine in it. BUT you may fit a supermoto (big single cylinder) engine in it. Thumbs Up
Bloggsy
PostPosted: 13:55 - 23 Dec 2017    Post subject: Reply with quote
Do a search for 400greybike.com or something similar, you should find all things NC30 and reliable info
If It Aint broke Don't Fix It
stevo as b4
PostPosted: 17:57 - 23 Dec 2017    Post subject: Reply with quote
I'd have aimed a bit higher for a project though than lumping in a big single personally.
If going down that route, the VFR's chassis is alot more capable than its original motor even. So some sort of twin 500cc+ would be the minimum amount of motor I'd be happy with, or maybe something two stroke or even a different V4.
Would a big VFR (750) motor have any chance of getting into an NC30 frame? Just thinking along the lines of bikes like GSXR 7/11's or ZX7/9R's?
dydey90
PostPosted: 20:03 - 23 Dec 2017    Post subject: Reply with quote
How much do you want for it?
I bet I could make that engine run even worse.
The last post was made 8 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.59 - MySQL Queries: 14 - Page Size: 51.03 Kb
