Fazer 600 (02) ignition set
MC900
PostPosted: 11:49 - 08 Jan 2018    Post subject: Fazer 600 (02) ignition set Reply with quote
Hi, my ignition barrel is a bit fucked as the flap doesnt close. Today i had to struggle as it was frozen and the key wouldnt turn.
Does anyone know where i can get a new ignition barrel, im assuming i need the seat lock and petrol cap stuff too? I have tried ebay but i cant find one for my year. I would prefer brand new but if used is the only way then that will have to do i guess.
Cheers.
Current Ride: Fazer 600 (02) & YBR125 (07)
davebike
PostPosted: 12:25 - 09 Jan 2018    Post subject: Reply with quote
From a Yamaha dealer but expensive my Wholesaler says £286.25 +vat ! that is guessing on a 5RT1 model look at vin plate fro your model or order using VIN ( frame) no.
I would keep searching for used !
A good spray of wd40 type may sort your existing mine plays up like this if not lubed 2003 FZ6 106K miles !
Dave
NC750Xdct + others at work !
davebike1@gmail.com
P.
PostPosted: 14:32 - 09 Jan 2018    Post subject: Reply with quote
Just put a dab of blue tack over the top or just get a little rubber cover.
thunderwow
PostPosted: 01:22 - 13 Jan 2018    Post subject: Reply with quote
If the above suggestions don't sort things or you are set on replacing the barrel then search for "FZS600 lockset" on eBay rather than Fazer - there were a few results when I checked just now ranging from £35 to £75. I don't think there is any difference between the 98-01 and 02-03 models for these parts.
You don't have to replace the filler or seat locks of course, provided that you're happy with using a different key for these to the one you use for the ignition.
MC900
PostPosted: 02:43 - 03 Mar 2018    Post subject: Reply with quote
Ìve searched and I've bought the wrong one and still can't seem to find the right one for my bike. Does anyone know where I can get the ignition switch for 2002/2003 fazer? Cheers.
The last post was made 6 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.1 - MySQL Queries: 17 - Page Size: 44.43 Kb
