Cold weather, bad battery and poor starting / running
barrkel
PostPosted: 16:03 - 08 Jan 2018    Post subject: Cold weather, bad battery and poor starting / running Reply with quote
As the weather turned colder, I noticed my Brutale had a harder time idling on startup. It comes with a little manual choke lever (despite being fuel injected), so I started using that and didn't think too much about it.
Then, some time in December, the electrics died a couple of times on attempts to start. I ordered a battery, waited for it to arrive, and put it on a charger, but wasn't in a rush to replace as the bike had only failed to start a couple of times.
Then, last week, coinciding with some wet weather, it appeared to intermittently run on 3 cylinders for a few beats at a time. It was hesitant riding down the road, and needed a decent bit of throttle to reliably accelerate off the line, and far more feathering when filtering. Once the bike had warmed up, though, it wasn't too bad. Wet electrics, I thought, perhaps a bad HT lead, possibly spark plugs. Before I tried taking the tank off and having a more serious poke around seeing what was connected to what, though, I replaced the battery last night.
This morning, it started up screaming with my usual application of choke, despite it being 4 degrees or so outside. There's no hesitation, no intermittent running, no feathering required, the bike is full of pep again.
Is it common for a dying battery to be such a drain on the electrics to cause bad running, to the point of missing sparks, like this?
doggone
PostPosted: 17:09 - 08 Jan 2018    Post subject: Reply with quote
If the charging system is working normally, there shouldn't be any low voltage issues when it's running.
It could be an ignition coil on the way out or HT leads as you suspected.
Alway first thing to check is for poor earth due to corrosion or dirt.
barrkel
PostPosted: 12:30 - 09 Jan 2018    Post subject: Reply with quote
It's running great right now - it's like it's up 20+ hp - and am not about to try and fix it when it's not broken. We'll see if things go bad again when it gets wet.
I get mixed results searching online for a causal connection between a bad battery and poor running. Some people swear it's not possible, others swear it's happened to them. So far, I'm in the latter camp.
Chris45
PostPosted: 15:38 - 09 Jan 2018    Post subject: Reply with quote
Thumbs Down
I would simply add the word "Intermittent" and advise you reread Doggone's post. Wink
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
P.
PostPosted: 19:27 - 09 Jan 2018    Post subject: Reply with quote
It is probably a fast idle btw, rather than a choke.
barrkel
PostPosted: 14:17 - 10 Jan 2018    Post subject: Reply with quote
I agree; it is, however, labelled choke.
P.
PostPosted: 21:25 - 10 Jan 2018    Post subject: Reply with quote
GSXR750Y I had was similar.
https://i.ebayimg.com/images/g/ScgAAOSwcLxYKJvu/s-l300.jpg
The last post was made 6 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.58 - MySQL Queries: 17 - Page Size: 56.12 Kb
