Which cctv to buy?
mudcow007
PostPosted: 20:44 - 16 Jan 2018    Post subject: Which cctv to buy? Reply with quote
Looking at replacing my cheaper cameras for something you might be able to identify someone from
My current setup is probably about 0.4mp Laughing
Looking at Hikvision, but been warned about loads of "grey imports" with no support/ firmware updates etc.
What do you all use?
bugeye_bob
PostPosted: 21:08 - 16 Jan 2018    Post subject: Reply with quote
Pretty much anything on the market will be a massive improvement over what you have then lol
Budget, how many cameras are required ?
Are you just looking to ID a person close to your property, or after a bit more ?
Even if the Grey imports dont update, if it works out of the box, why update, if the system offers the functionality when you buy it, why risk updating ?
Ive fit all sorts budget wise, commercial and domestic, the ££ does dictate the quality, but even the more expensive are plastic housings, and the cables are no different to the "cheap" ebay ones now,
A few years ago you could really tell the budget quality, but I cant slate it now.
Just to add, even if you have a 4 camera now, and think its fine, buy a 8 channel, for the difference in cost, its worth it and gives you options in the future.
mudcow007
PostPosted: 21:16 - 16 Jan 2018    Post subject: Reply with quote
cheers for that, it makes sense over f/w
what i have seen so far is
DS-7204HQHI-K1 for the DVR
DS-2CE56F1T-IT3 for the cameras
I'm only saying 4 channel as my house is literally like a shoe box, 3 cameras will easily cover the whole property.
Beehive Bedlam This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
janner_10
PostPosted: 00:21 - 17 Jan 2018    Post subject: Reply with quote
We have a HikVision system at work, around 20 cameras.
It plays back and records nicely, been in situ for about 12 months.
Remote access blah blah.
Not arsed about grey imports or imports of any other colour, it just works fine.
Nothing else to say really.
ferrisio
PostPosted: 02:13 - 17 Jan 2018    Post subject: Reply with quote
Don't mess about with analogue cameras nowadays, get a PoE switch and IP cameras and an XVR. Even if the hardware is a few percent more expensive, you'll save on cabling costs and general simplicity of installation. For instance, you don't have to run all the cables back to the XVR, just to the switch which can be hidden out of the way somewhere, which also means the XVR can be somewhere convenient.
Couldn't quite tell from the models you quoted whether they were IP or not, looked as if they weren't.
BMW R1100R
bugeye_bob
PostPosted: 10:25 - 17 Jan 2018    Post subject: Reply with quote
They look ok, not the best, but Im guessing that 7 x better than your current is going to be a big improvement,
I would guess these would still utilise the current wiring anyway ?
So no worries there.
P.
PostPosted: 10:40 - 17 Jan 2018    Post subject: Reply with quote
Hikvision have humourous security at best. Many schools use it but we exploit it and tell them why we won't expose to the web.
DIY, gearbest some 1080p cams, Nas and BlueIris. Job done for sub 200.
panrider_uk
PostPosted: 10:46 - 17 Jan 2018    Post subject: Reply with quote
We use Hikvision cameras for our external CCTV and d-link for the ones monitoring the internal factory areas.
Both work well.
I've installed cheap (< £100) Hikvision dome cameras at my sister's house and they're really good quality for the money - better than my £300 Lilin camera.
I like the Synology NAS solution as it gives you a device that can be used for much more than just CCTV storage.
It comes with a CCTV package (Surveillance Station) that handles a very wide range of cameras and will email you snapshots of any detections if you want it to.
If you want more than 2 cameras you do need to buy extra licences though at about £40 each for a lifetime licence.
Current bike: Honda ST1100
P.
PostPosted: 17:25 - 17 Jan 2018    Post subject: Reply with quote
I use a generic brand chinese 1080p night camera and its better quality than our Axis cameras at work...
Buying the right camera can be very easy.
mudcow007
PostPosted: 21:11 - 17 Jan 2018    Post subject: Reply with quote
Its "buying the correct camera" bit that i'm struggling with.
I don't really want to shell out £300 pair camera
The ones I currently have are from a "kit" on eBay, that were supposedly HD (dont laugh at the back) but they are shite.
Hence why I was going to go with a brand
bugeye_bob
PostPosted: 21:46 - 17 Jan 2018    Post subject: Reply with quote
When looking at camera`s,
the higher the TVL the better quality the image,
the smaller the lens 2.8 mm the wider the viewing angle, but you loose some distance, the bigger the lens ie 6 mm the narrower the viewing angle, but it will bring things further a field closer, most are 3.6mm,
the bigger the TVL the more storage each file will take up on the HDD,
Buy a decent size HDD,
https://dcsithub.com/images/compare_camera_Quality/security-camera-resolutions.jpg
https://wcctv.co.za/wp-content/uploads/2017/12/CCTV-Camera-lens-images.jpg
oldpink
PostPosted: 21:55 - 17 Jan 2018    Post subject: Reply with quote
I bought a floureon 4 camera cctv system for £25 from gear best came with a 8 channel DVR but no HD
threw in an old 350gb laptop drive I had spare works a treat for £25 total inc delivery
bugeye_bob
PostPosted: 22:00 - 17 Jan 2018    Post subject: Reply with quote
trew in an old 350gb laptop drive I had spare works a treat for £25 total inc delivery
My mate has one of these, had no issues, 350Gb cant last that long even with the 4 cameras ?
you should stick a £1.50 microphone up, you catch all sorts lol
Mark65
PostPosted: 17:02 - 18 Jan 2018    Post subject: Reply with quote
I have a Hikvision camera and recorder POE system at home, works great.
mudcow007
PostPosted: 20:47 - 18 Jan 2018    Post subject: Reply with quote
My current kit is a "floureon" branded an its pants.
Id say my garden gate is prob 25ft from the camera an peoples faces look like the attached picture
Maybe I got a duff kit?
bugeye_bob
PostPosted: 21:23 - 18 Jan 2018    Post subject: Reply with quote
You have already stated that's it's old kit, how old and what spec is it ?
P.
PostPosted: 21:27 - 18 Jan 2018    Post subject: Reply with quote
I use these - https://www.aliexpress.com/item/BESDER-HD-IP-Camera-1080P-960P-720P-Bullet-Cam-2MP-Lens-IR-IP-CCTV-Security-Camera/32835984507.html?spm=2114.search0104.3.56.73f35a27p0IXcD&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10151_10065_10344_10130_10068_10324_10547_10342_10343_10340_10341_10190_10084_10083_10615_10307_10301_10303_10313_10059_10314_10184_10534_100031_10604_10103_10142,searchweb201603_25,ppcSwitch_5&algo_expid=17b54ffa-6604-4335-9334-5902483656e9-7&algo_pvid=17b54ffa-6604-4335-9334-5902483656e9&priceBeautifyAB=3
As long as you have a decent bit of software, BlueIris for example, it'll be perfect.
recman
PostPosted: 21:30 - 18 Jan 2018    Post subject: Reply with quote
More importantly, how does he know Bill Clinton?
oldpink
PostPosted: 15:52 - 19 Jan 2018    Post subject: Reply with quote
pretty decent image of most of my garden area
P.
PostPosted: 17:44 - 19 Jan 2018    Post subject: Reply with quote
To me that just isn't clear enough. Even my cheapo chinky ones give you crystal clear quality and are POE. I highly rate them.
(I've tried many of the chinese ones, the ones I linked at the best for that price.)
bugeye_bob
PostPosted: 10:16 - 29 Jan 2018    Post subject: Reply with quote
3 out of 4 look out of focus !
There is a gap of 1 year, 23 days between these two posts...
BensonChiang This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
M.C
PostPosted: 14:58 - 21 Feb 2019    Post subject: Reply with quote
Do not purchase from cctvoutlet its an ISIS front.
sickpup
Old Timer
PostPosted: 16:12 - 02 Mar 2019    Post subject: Reply with quote
Please elaborate or should we email them and ask them to comment?
The last post was made 5 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.76 - MySQL Queries: 17 - Page Size: 132.45 Kb
