Big bore kits for 125cc - Yes or No?
Teflon-Mike
tl;dr
PostPosted: 00:00 - 23 Jan 2018    Post subject: Reply with quote
The seals are about £7 a pair.
The oil to refill the fork legs is about £30 a liter.
Its cheaper to swap the fork seals than loose a leg full of bludy oil!
PostPosted: 13:27 - 23 Jan 2018    Post subject: Reply with quote
I have to say I noticed Tef said that and thought it ridiculous, but my tef filter is too attuned these days.
Teflon-Mike
tl;dr
PostPosted: 17:57 - 23 Jan 2018    Post subject: Reply with quote
Last bottle of fork-oil I bought, was probably three or four years ago, and Alzheimer is probably kicking in, but I was sure it cost me about £10-£15 and was only half a liter.
Either way, cost of oil, is at least as if not more significant than seals, so why waste oil to find out of seal shot, just swap the seal, and be done!
Pigeon
PostPosted: 19:42 - 24 Jan 2018    Post subject: Reply with quote
I is confused (more than normal)
What has fork oil got to do with big bore kits?
ThatDippyTwat
PostPosted: 19:54 - 24 Jan 2018    Post subject: Reply with quote
Tef got confused and posted on the wrong thread - kinda like he get's confused and thought he was a bike instructor. Bless.
PostPosted: 20:25 - 24 Jan 2018    Post subject: Reply with quote
Let's see where this goes. Shhh!
bladerunner
PostPosted: 22:54 - 25 Jan 2018    Post subject: Reply with quote
stevo as b4 wrote:
People have been fitting big bore kits to 125's for over 30 years, and I bet a few RD125LC owners put their first Autisa 175 kit on circa 1983?
Funny that....I have an RD125LC AND I'm about to fit a spanking new Autisa 175 kit on it...took me years to find an unused one this time tho Laughing Laughing
bikenut
PostPosted: 12:56 - 26 Jan 2018    Post subject: big bore kit Reply with quote
Many many many moons ago ( 1970's ) when cb125s 's where everywhere, in the monthly mags there was a big bore kit advert usualy in the back of the mags, a small black and white box add with real cool artwork of an oversized cb125s engine, would anyone have the mag with the advert in please ??????
nuts about bikes
stevo as b4
PostPosted: 13:28 - 26 Jan 2018    Post subject: Reply with quote
Oh the good old back in the day tuning ads in magazines!
I remember the TTS ads, Stan, Bob, and uncle Frank's adverts too.
Point being almost anything could be or was being tuned in them days. People used to use and mess with whatever bike they had. None of this save your money for a scabby old superbike instead.
Turbocharged superdreams and all that for the fun of it. Laughing
bikenut
PostPosted: 13:50 - 29 Jan 2018    Post subject: ad Reply with quote
anyone have old monthly bike mags with that advert in it please, been searching for it for ages now, years in fact.....anyone ??
nuts about bikes
1198
PostPosted: 22:13 - 01 Feb 2018    Post subject: Reply with quote
Bozzy. wrote:
OP,
....bolt a dirty great big turbocharger to it....
https://youtu.be/TD6YAvw_B6o
That's awesome (if it's real)! I big bored a Chinese 125 to 150, fitted a free flow filter, geared it up, and fitted a bigger carb. Not a massive difference, noticeable though, and the whole lot coat less than £150 as I recall.
Oh, the dvla and your insurance should be told, and you'll need a full licence too...
dydey90
PostPosted: 22:37 - 01 Feb 2018    Post subject: Reply with quote
No. HELL NAW. If it says 125 on the side, an inspector isn’t going to look further than that. The only trouble you’re going to get into is if you’re caught at silly speeds.
1198
PostPosted: 00:54 - 02 Feb 2018    Post subject: Reply with quote
Please note the word 'should'....
There is a gap of 1 year, 197 days between these two posts...
kemeng
PostPosted: 05:28 - 18 Aug 2019    Post subject: Reply with quote
Late reply, but Im just in this process. I cannot say yes or no, it is depends:
If you upgrade:
- get proper kit which has good reputation, trusted. Price wont tell you so much: Got Takegawa kit (139cc) made for my bike (xtz125 - almost same engine with ybr or xt) was nice, runs smoother than original set till 1700km-s. Even I broke in slowly and with soft wrist (1500kms, 5x oil change, built up from short rides low end till extended top end). Means when it got the same grade syntetic oil and cooler brisk spark (used to use before) made only 200km.
- got 144cc (57.4) kit then from UK seller with higher lift cam (half price than Takegawa). Piston is heavy or cam is too much (and/or bad timing) heats up like hell, cannot go over 6-6500rpm or riding more than 30min (and used to use make 270-300kms in one run). Definitely the quality of materials are good otherwise it supposed to be blow up already. We will take out the cam, and see how is without.
- as I ride in jungle/rural area 2-600kms daily (do motorbike tour) I need thrust at this moment I cannot use that bike.
- may you need bigger carb or set original properly (lean=heat) , more airflow (open the airbox), thicker front pipe, better muffler and lots of patience, time, cash and pray.
- you wont get more top speed btw (max 1-5km/h), you will have better accelation. If you want more speed change sprockets
- found now a Nikasil coated, forged piston set (airseal brand), will go with that with all everything else stock. I would chose that kit first, If I could see it before. (So spend lots of time, money etc for nothing).
- C plan if you want little more braap and thrust is Wiesco forged piston (original 54mm size or oversized) made for YFM125 RAPTOR (as it has same piston, engine as mine and definitely ybr or xt)
- there are kits for 180cc but you have to open, make bigger everything and you cannot use the bike for cruise anymore that sure. I would even change that many chinise bearings from engine to quality C3 clearence ones (done btw as balancer bearing blow up too sometime)
- If you find the perfect kit and settings (hope the nikasil will be fine) than you can save money over the original cylinder/piston/ring/pin/gasket price (50% cheaper at a least). If not, just read back what I've written above.
If you remain at stock:
- got a Honda 125 too, it has 77000km's and still running (almost:) like new (next to this tropical, seaside weather conditions). I am strictly use original engine parts with (never rebore even - change whole kit as cost 50USD only:) . It has never stopped, never left me somewhere middle of jungle or nowhere.
BusterGonads
PostPosted: 08:34 - 18 Aug 2019    Post subject: Reply with quote
Waste of time obviously, but I thought this wheelying turbo charged CG125 was quite funny.
https://www.youtube.com/watch?v=yLxxipyMCsw
Most of these turbo cg125 films show some saddo pointing a camera phone at a cobbled together lash up in a dark Pakistani garage and have the motor ticking over roughly. This one is hurtling down the street and going up on its back wheel in second or maybe third gear.
Doubt it does a lot for the engine reliability. Probably like those early Nazi jet planes that had a new engine every two or three quick flights.
2016 Triumph Street Twin; 2000 Honda CG125; 1997 Honda Nighthawk CB250
The last post was made 4 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.12 - MySQL Queries: 17 - Page Size: 100.58 Kb
