1979 Suzuki TS 125 project
Fastredcat
PostPosted: 16:17 - 22 Jan 2018    Post subject: 1979 Suzuki TS 125 project Reply with quote
This is my recently obtained toy , planning on restoring it , her name is Jane [/img]
PostPosted: 16:49 - 22 Jan 2018    Post subject: Reply with quote
You know that nitromorse will strip the paint off that tank with minimum effort? Flapper wheels is doing it the hard way.
Suntan Sid
PostPosted: 22:44 - 22 Jan 2018    Post subject: Reply with quote
Since they changed the nitomors recipe, a flap wheel may be the 'hard way' but it is now the quicker way!
Tried each on two tanks, chemicals took forever, wire wheel took about 40 minutes!
PostPosted: 00:13 - 23 Jan 2018    Post subject: Reply with quote
Oh, and while it seems like makingextra work. Re-check the tan is fuel-tight BEFORE you paint it. Sometimes the paint was the only thing blocking a pinhole. Best to find out first! Or just POR15 it when it's stripped.
I can also recommend taking some steps to protect against the adverse effects of ethanol at the build stage. Particularly fuel lines, gauze filters, fuel tap gaskets and needle valves or you risk running into problems 6 months down the line. A'79 bike was not built to deal with it.
Fastredcat
PostPosted: 07:36 - 23 Jan 2018    Post subject: Reply with quote
Thank you
The last post was made 6 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 17 - Page Size: 46.06 Kb
