Rogerborg |
Rogerborg nimbA
MCN |
MCN Super Spammer
Rogerborg |
Rogerborg nimbA
Posted: 12:54 - 06 Feb 2018 Post subject: |
They'll get Lidl "branded" and like it. ____________________ Biking is 1/20th as dangerous as horse riding.
MCN |
MCN Super Spammer
bacon |
bacon World Chat Champion
Vracktal |
Vracktal World Chat Champion
Rogerborg |
Rogerborg nimbA
Posted: 15:25 - 06 Feb 2018 Post subject: |
Better for him and no difference for you if it failed then passed. I'm going to ask my chap if he'd like to fail my Tractor on that. ____________________ Biking is 1/20th as dangerous as horse riding.
M.C |
M.C Super Spammer
Copycat73 |
Copycat73 World Chat Champion
Posted: 18:46 - 06 Feb 2018 Post subject: |
so i takes the ZZR14 for its test .. Oh he says .. those front brake pads are a bit low ... i never noticed ...
upon my inspection .. which requires caliper removal ... one of the pads de-laminated ... i won`t tell you how fast i applied the brakes on the way home ..
so frankly if your bike is a hazard then you need to know ....
and the other thing is ...presentation is vital for any inspection ..
clean & Tidy ...
____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
andym |
andym World Chat Champion
Posted: 18:53 - 06 Feb 2018 Post subject: |
So I done the work and it passed it's MOT, I even took pictures of some of the work, when I got there it was a different tester today who just pushed the bike over slightly to check the back wheel and the tyre still moved a bit (I really should check the pressure)
Excessively slack chain:
https://i.imgur.com/oWnkvOx.jpg
Adjusted with exactly 1 inch of movement:
https://i.imgur.com/5N2t1WT.jpg
Knocking out the old bearings:
https://i.imgur.com/Swlimqr.jpg
Knocking in the new ones:
https://i.imgur.com/JoZvt98.jpg
https://i.imgur.com/gexmBXy.jpg
On the way to the MOT station there was no feeling to the throttle, it used to require a slight amount of effort to turn, now it just feels like it's floating and even the slightest touch has the revs up at 5-6k when pulling away.
Pre-post edit:
Copycat73: clean and tidy ma baws, I cleaned some of the winter shit off it, sorted the parts that had stuck, replaced the parts I knew needed replaced (rear brake pads).... then rode it around until the MOT was due |
1198 |
1198 World Chat Champion
Copycat73 |
bacon |
Posted: 19:57 - 06 Feb 2018 Post subject: |
1198 wrote: | bacon wrote: | My bike passed an MOT today, ZX7R, done 500miles since a clean sheet last year.
Advisories
*Rear wheel bearings have gone rough... apparently
*Both fork stanchions have misting of oil - it is acf50, my shed gets damp sometimes so I coat everything, my fault for not wiping it off.
*Valve stem slightly damaged - this garage seem to love valve stems, they replaced one on my sv1000 last MOT and gave an advisory for the other
*Loose chain, it isn't loose. I adjust it to 25mm travel at the centre of the chain, got the same advisory on my sv1000
I just think some are more fussy than others.
Until they fail me for something stupid I don't care! |
Valve stem? What? Where? How? |
Not the valves you're thinking! Tyre valves, they seem to love hunting for cracked rubber stems. Only a fiver to replace them last time, but they will be changed at the next tyre change anyway, go figure. |
Shaft |
Shaft World Chat Champion
Posted: 22:18 - 06 Feb 2018 Post subject: |
The first thing to remember is, MOT testers are not (or shouldn't be) actively looking to fail anything - there are one or two things, usually safety critical, where there are no options other than pass or fail, but where a tester can use discretion, the rule of thumb is pass and advise, where possible.
Having said that, some testers are more picky than others and there are definitely a tiny number that go way OTT.
My view has always been, if I would happily ride it up the road, then it's a pass, however, if I find more than a couple of advisories in the first five minutes, I'm looking for stuff to fail, because the indications are it's been, at best, sloppily maintained, at worst it's outright neglect.
Silly advisories, like perished valve stems, are a combination of playing the arse covering game and making sure that, if there's an audit, DVSA Derek knows the tester isn't missing anything; again, some testers go out of their way to find obscure things to advise, but I've seen it backfire, where the guy was so intent on being infinitesimally picky, he missed an obvious fail.
And do clean your bike a bit, it's the first part of passing the attitude test, which can go a long way. ____________________ Things get better with age; I'm close to being magnificent........
Posted: 22:46 - 06 Feb 2018 Post subject: |
My local car guy also does bike MOTs. Every time I take the VFR he does an advisory on the brake pad depth. I point out they are sintered pads and nearly brand new. He expresses surprise that they do sintered pads for motorcycles.
My local motorbike guy, who I use when he can fit me in has found a couple of things that I'd missed over the years. Most noteable were cracks propogating from the drillings on my rear disc. He is a decent chap and said it should fail but as long as I promised to go straight home and not move the bike until the disc's replaced, he'd pass it. I did.
The enfield keeps shitting the bed with MOTs. It's twice now had the wheel bearings collapse on the way to the MOT (front one year, rear the next). The last time was comical because they fully crapped themselves. He actually shouted over to me "What the fuck do you call that?" as he was wiggling the rear wheel visibly from side to side with the bike on the kickstand. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Wonko The Sane |
Wonko The Sane World Chat Champion
MarJay |
MarJay But it's British!
Rogerborg |
Rogerborg nimbA
Posted: 10:05 - 07 Feb 2018 Post subject: |
Bennetts point out that the MOT pass rate for bikes is higher than for 40+ year old vehicle that have just been made MOT exempt on the basis that they're so super-well maintained. ____________________ Biking is 1/20th as dangerous as horse riding.
Jewlio Rides Again LLB |
Jewlio Rides Again LLB World Chat Champion
MCN |
MCN Super Spammer
DJP |
DJP Crazy Courier
Posted: 13:57 - 08 Feb 2018 Post subject: |
Are some MOT testers just c**ts?
Sadly, yes.
Like the one in my local bike shop who failed my bike on "Worn brake pads" that were actually new. ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
Rogerborg |
Rogerborg nimbA
Posted: 14:38 - 08 Feb 2018 Post subject: |
Passed, legit advisory on the rear pads which still have several microns left, but a totes bogus one on a slack chain which is well racist against bikey bruvs because it tensions up a fair bit under load and Herr BMW specifies the 40mm of movement that I'd just adjusted it to.
So the biscuits stayed in the top box. ____________________ Biking is 1/20th as dangerous as horse riding.
trevor saxe-coburg-gotha |
Howling Terror |
Howling Terror Super Spammer
The last post was made 6 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
