Vfr1200f minimum brake disk thickness
Dave81
PostPosted: 12:19 - 09 Feb 2018    Post subject: Vfr1200f minimum brake disk thickness Reply with quote
Hi all,
As the title says, does anyone know off the top of their heads what the minimum thicknesses are for the brake disks are as I can't find them in the service manual. Thanks
wr6133
PostPosted: 12:52 - 09 Feb 2018    Post subject: Reply with quote
It's usually etched on to the discs
Confusion
PostPosted: 00:00 - 10 Feb 2018    Post subject: Re: Vfr1200f minimum brake disk thickness Reply with quote
Dave81 wrote:
Hi all,
It should be marked on the centre of the disc, close to the
holes for the mounting bolts. There are a few VFR1200 FRONT discs
listed on eBay with clear photographs. They are marked
MIN TH. 3.5mm.
Example:
https://www.ebay.ie/itm/2010-HONDA-VFR-1200F-FRONT-LEFT-SIDE-BRAKE-DISC/262943309662?hash=item3d38a47f5e:g:LosAAOSwcdRY9v5f
Bandit 650SA, ZZ-R1100
Dave81
PostPosted: 04:01 - 10 Feb 2018    Post subject: Reply with quote
Thanks for the replys gents, I will take a look, 3.5mm sounds promising though, which is good, as it saves a £300 pound investment for the front for another year if correct.
Dave81
PostPosted: 18:34 - 10 Feb 2018    Post subject: Reply with quote
3.5mm was spot on, thanks again guys 👍
The last post was made 8 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.2 - MySQL Queries: 14 - Page Size: 41.72 Kb
