No Headlights?! Any sparkies?? Sinnis Shuttle
crb553
PostPosted: 20:25 - 06 Feb 2018    Post subject: No Headlights?! Any sparkies?? Sinnis Shuttle Reply with quote
Hi everyone, I have a 66-plate Sinnis Shuttle 125.
The headlights (low & high) do not work. They are supposed to come on automatically when the engine is started and go off after switching off.
Battery fine
All of the earths appear to be ok
Switch ok
All other lights work
When power is applied from another source through the loom from switch terminal they light up!
So it’s just a case of getting power to them? I’m not sure if there is something that regulates this tucked away somewhere which powers them when engine is running...?
Any ideas would be great!
Thanks
PostPosted: 20:33 - 06 Feb 2018    Post subject: Reply with quote
It'll either be the earth from the bulb or the power to the switch. Are there any fuses on the bike?
Triumph Sprint ST 1050
crb553
PostPosted: 20:40 - 06 Feb 2018    Post subject: Reply with quote
One main fuse next to battery, working.
If it was bulb earth they wouldn’t light up when power applied from a separate source, which they do :/
UncleFester
PostPosted: 20:51 - 06 Feb 2018    Post subject: Reply with quote
So you're not getting power to the switch or the switch isn't passing power to the lights.
Corrosion inside the switch on the terminals?
Multimeter is your friend.
2017 Z1000SX
RhynoCZ
PostPosted: 21:06 - 06 Feb 2018    Post subject: Reply with quote
If it was the main fuse, you would get no power past that fuse, that's why they call it the main fuse. Thumbs Up
UncleBFester might be right. Do you have a contact cleaner? Just spraying it inside the switch and moving it around a bit might help.
crb553
PostPosted: 21:07 - 06 Feb 2018    Post subject: Reply with quote
We aren’t getting power to the switch I think.
Switch works fine.
Power for all other lights comes from the battery no problem when ignition turned on.
RhynoCZ
PostPosted: 21:08 - 06 Feb 2018    Post subject: Reply with quote
You didn't mention the bulb was alright, try a different bulb. Not likely to be the issue, but hey, why not to try. Also check the plug for corrosion/oxidation (green/white stuff).
EDIT: Just a wild guess, could your issue be caused by damaged wiring? A missing grommet to the headlight, the wires rubbing, now shorting out? Thinking
crb553
PostPosted: 21:11 - 06 Feb 2018    Post subject: Reply with quote
Should have made that clearer, bulbs are ok. If we apply power to the switch using a piece of wire the headlights come on and the switch operates high / lo as it should.
RhynoCZ
PostPosted: 21:14 - 06 Feb 2018    Post subject: Reply with quote
Now we're getting somewhere. What type of charging system does your motorcycle have? Could it be that one phase of the alternator powers up the lights? That phase dying (or just corrosion/oxidation = mostly green/white stuff in the plug from the alternator) could cause what you're experiencing. Thinking
crb553
PostPosted: 15:48 - 07 Feb 2018    Post subject: Reply with quote
Thanks for all the replies people.
For info- Turned out to be a headlight relay, located under the seat! Smile
The last post was made 8 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 62.88 Kb
