colink98 |
colink98 Could Be A Chat Bot
ADSrox0r |
ADSrox0r World Chat Champion
Kawasaki Jimbo |
davebike |
davebike World Chat Champion
Posted: 11:53 - 08 Feb 2018 Post subject: |
Stator check
Stator test
three wires out usually yellow or white
any one to -ve (earth) more than 30M ohms
between any pair (three tests) between 0.3 and 2 ohms
Also check power (RED) and earth (GREEN) wires from rec reg to battery are low resistance Honda looms can fail ! ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
Posted: 12:36 - 08 Feb 2018 Post subject: |
Can also do a dynamic test on the stator. AC voltage between each pair of yellows coming off the stator with the engine running. See if there's an increasing output with rev speed that's roughly consistant between each pair.
Be aware it can be a high enough voltage to give you a dunt so don't hold onto the wires. I've seen >70VAC. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 6 years, 78 days ago. Instead of replying here, would creating a new thread be more useful? |
