Rg125 gamma cutting out under load
salem1987
PostPosted: 18:37 - 15 Feb 2018    Post subject: Rg125 gamma cutting out under load Reply with quote
Weird problem.
Bike cuts out when setting off in first, fethering the clutch at all manor of rpms up to red line.
Put the bike on a paddock stand and put it in any gear and its fine, using the clutch or not.
I thought clutch switch or sidestand switch, but no there isnt one and besides it runs fine off the ground.
Engine and bike has just been rebuilt from the ground up and revs out cleanly on the bench.
The cutting out is like a switch being pulled when the clutch is fully disengaged, no bogging or stumbling.
Any ideas?!
Edit: i've ridden many different 2 strokes in various forms so know they differ to 4 strokes with regards to keeping the rpm up! Razz
stevo as b4
PostPosted: 20:30 - 15 Feb 2018    Post subject: Reply with quote
Does it cut out in 2nd>?
Is it sudden like an electrical short, maybe a wire rubbing on the frame when your sat on it, or similar?
Is the fuel flow ok from the tank to the carb, and is the tank breather clear?
If not I'd maybe try another CDI if you can just to prove it's OK?
jaffa90
PostPosted: 21:56 - 15 Feb 2018    Post subject: Reply with quote
Has it got an air filter fitted and have you tried blocking some of the air intake as in old fashioned choke.
salem1987
PostPosted: 23:42 - 15 Feb 2018    Post subject: Reply with quote
it cuts out in any gear yes.
Its very odd, it has the classic symptom of a failed clutch switch but there is not one present. Cuts out at the same exact point (about 3/4 release of clutch) when sat on the bike or if the rear wheel is on the floor and i try walk with it. It does start to move as the clutch bites. But its also completely fine with the wheel off the ground.
I'll check the wiring next, and the fuel flow.
I've not tried the hand choke method will give that a go aswell.
Thanks for the advice
salem1987
PostPosted: 20:13 - 16 Feb 2018    Post subject: Reply with quote
update:
Nothing seemed to solve it. While the bike was running i checked the chain tension. Every time i gripped the chain tight it cut out?!
Left engine cover off, found a frayed wire that somehow touched the chain when it was tensioned. Must have been doing this when trying to ride it with load but not with the wheel free spinning.
Wire insulated..
Solved!
stevo as b4
PostPosted: 22:58 - 16 Feb 2018    Post subject: Reply with quote
Thank God for that!
Id forgot to ask you what happens if you bump start the bike, but think I was having trouble understanding or interpreting your exact description of the fault.
Common Internet problem when you can't see the issue or talk to the person with the problem.
Glad you sorted it though.
jaffa90
PostPosted: 00:25 - 17 Feb 2018    Post subject: Reply with quote
Well done stevo.
The last post was made 6 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.32 - MySQL Queries: 18 - Page Size: 56.65 Kb
