My honda cg clutch is wobbling on the shaft
PerithTV
PostPosted: 19:51 - 13 Feb 2018    Post subject: My honda cg clutch is wobbling on the shaft Reply with quote
What happend was i was riding along on my honda cg 125 1996 and was in 4 gear doing 50mph when the engine lost all power i then pulled in the clutch dumped it. The bike started running agian but when i went above a certain rev point the bike would hit a redline (not the actual redline) and would actually start to lose power and would get very hot. i got the bike home just about. I thought it must be the clutch so i opened it up and the clutch wobbles on the shaft like this.
https://www.youtube.com/watch?v=J4Xc5jMN_ws
I never opened the clutch up before but i doubt that much play in the clutch is normal. I'm waiting on the 4 point socket at the moment to remove the oil filter while i wait what do you think the problem is? I can't get to the clutch basket to check till the socket arrives so it would be good if i can get the right part as i get the socket. Also while im here i'm going to replace the plates, steels and springs.
thanks for reading !!!
PostPosted: 10:56 - 14 Feb 2018    Post subject: Reply with quote
Custard test time.
6 year old, French youtube video is 6 years old and French.
Please post a picture of your heat-seized CG125 with a pot of custard in the shot to prove you are a real person.
Given current evidence, I'd suggest it's been left lying in the road on its side with oil spilling everywhere.
PerithTV
PostPosted: 11:39 - 14 Feb 2018    Post subject: Reply with quote
You would never believe me if i said it but in 2018 i don't actually own a camera
bikenut
PostPosted: 12:08 - 14 Feb 2018    Post subject: aldi Reply with quote
go to aldi and get the cheap go pro camera, you will need it !
a kid with no camera phone in this day and age !
I only have a normal phone, one that does not make the toast, but I'm over 60 ! :D
ps you know of cmsnl and don't forget a new gasket.
Think why it would be a bad idea to use gasket sealer in this application ?
nuts about bikes
PostPosted: 13:30 - 14 Feb 2018    Post subject: Reply with quote
Well, I doubt it's a clutch problem in any case from what you describe. Sounds like a heat seizure. That will require a top-end strip down at a minimum to investigate. As a first step I'd have a look at the plug electrode, see if it looks scorched/white/nibbled.
The only time I've known a CG125 to heat seize is if it ran out of oil or has been fucked about with in a hipster fashion by removing the airbox and fitting a straight through pipe without setting it up to suit. I suppose an oil pump failure could also do it but this would be a very rare occurrance on a CG125.
Given you claim to not have a camera, it can't be hipster nonsense because how would you put pictures of it on instagram otherwise?
So, what was the oil like that came out and was there as much of it as there should be?
PerithTV
PostPosted: 14:54 - 14 Feb 2018    Post subject: Reply with quote
I do have a camera on my phone however my dog is a right lad and thought it would be funny to chew my phone the cameras cracked and so is the screen!
One thing i did notice is that the oil pump was not seated properly. I'm gonna take off the cylinder head tonight to see what the barrel and piston are like brought a gasket kit as well as i know i'm gonna need it for the top end and the clutch cover. One of the things i'm thinking is maybe one of the rings has snapped and the other one just kept the compression high enough to keep it running. The bike will still start. however i cannot get it to idle no matter where i position the mixture screw in less i ramp up the idle to scary grunting levels.
plug also looks grey is but more towards the darker grey meaning it was running on the lean side a lot of carbon on the tip of the plug as well.
PostPosted: 16:08 - 14 Feb 2018    Post subject: Reply with quote
Really?
And no one else you know has a camera phone or any other sort. Are you a Billy No Mates?
Triumph Trophy Launch Edition
PerithTV
PostPosted: 21:09 - 14 Feb 2018    Post subject: Reply with quote
My dogs my mate
PerithTV
PostPosted: 22:39 - 15 Feb 2018    Post subject: Reply with quote
went and got myself a iphone 5 sadly no custard. Also I found the problem a snapped valve spring. Don't know if anyone has ever had this issue on their cg. But if u ever have my symptoms i hope this helps now for some juicy pictures
https://i.imgur.com/V0z8rIs.jpg
https://i.imgur.com/Du71XSb.jpg
https://i.imgur.com/7E9WUHq.jpg
PostPosted: 14:00 - 16 Feb 2018    Post subject: Reply with quote
That's an odd thing to happen.
Makes me wonder if it became coil bound. Tappet could have closed up. Have a good look round the valve seat for signs of scorching.
The last post was made 6 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.35 - MySQL Queries: 17 - Page Size: 68.39 Kb
