Chain Monkey
AshWebster
PostPosted: 14:13 - 14 Feb 2018    Post subject: Chain Monkey Reply with quote
Just saw it on Dragons' Den. Seems a bit OTT really?
Thoughts?
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
Monkeywrenche...
PostPosted: 14:46 - 14 Feb 2018    Post subject: Reply with quote
Bogeyman wrote:
POS.
I know if my chain needs adjustment which is almost never (i have a scottoiler) just by feel when riding the bike or just by looking at it.
I don't get your point, It's for chain adjustment not telling you if it needs doing.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
Rob Fzs
PostPosted: 14:51 - 14 Feb 2018    Post subject: Reply with quote
seems pointless to me, if you can work out how to use that, why cant you work out how to tighten a chain the old fashioned way
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
Monkeywrenche...
PostPosted: 14:59 - 14 Feb 2018    Post subject: Reply with quote
Ok I've looked at it, I struggle to see the stage of the process that this makes quicker/easier. Anyone?
Also LOL at him and the turkish guy planning to use it for bicycles, only fixed gear bicycles would be able to use it surely? and do any of those need this much accuracy in the chain tension?
PostPosted: 15:03 - 14 Feb 2018    Post subject: Reply with quote
Sounds like Rainpal will have a potential Joint Venture with Chain Monkey.
To much precision for something that doesn't really (Phuquing Phone Spelbot.) need to be so precise.
And correctly adjust chain is after you find the tightest section/run.
PostPosted: 15:10 - 14 Feb 2018    Post subject: Reply with quote
Fixed gear/single speed/hub gear push bikes want pretty much no slack at all at the tightest point of the chain.
Other push bikes have deralieurs or some other chain tensioning device.
Freddyfruitba...
PostPosted: 15:11 - 14 Feb 2018    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=309042
PostPosted: 16:28 - 14 Feb 2018    Post subject: Reply with quote
Rogerborg wrote:
Hang on, that trinket appears to introduce an absolute amount of slack dependent only on the vertical movement specified in the manual.
How does that take into account the length of the chain? Not the pitch, the distance between sprockets.
25mm of vertical movement in a short chain needs more slack than 25mm movement in a long one. But that gadget will give you the same amount of slack for either one.
Seems a bit 5-quarter-turns-in-a-circle.
PostPosted: 17:18 - 14 Feb 2018    Post subject: Reply with quote
It would be good for wheelbuilding. It's effectively a deflection tensiometer. An inaccurate but very cheap one.
AshWebster
PostPosted: 17:32 - 14 Feb 2018    Post subject: Reply with quote
He got backing from the Den i dont know why - its not an ingenious invention or an actual problem....
Commuter_Tim
PostPosted: 19:42 - 14 Feb 2018    Post subject: Reply with quote
Have they actually banked that cheque though?
There have been plenty of people the dragons agreed to invest in provisionally, and then backed out after they find out the product is shit.
I ride a Bandit 600... badly.
Hawkeye1250FA
PostPosted: 20:00 - 14 Feb 2018    Post subject: Reply with quote
citation needed....
Also who the fuck needs help knowing how tight the chain needs to be?!?
You've already done the "hard bit"
Undone all the correct nuts
Chained bike to lamppost
Retrieved it from breakers yard
But in all seriousness, does it not solve a non-existent problem? Although credit to them - it is an ACTUAL product. Not like the latest evolution of rainpal made from unicorn scrotums ....
Ed Case
PostPosted: 23:39 - 14 Feb 2018    Post subject: Reply with quote
I've managed for over 50 years without one of these contraptions...pointless. You don't need one, use your common-sense....it works fine !.
Kentol750
PostPosted: 00:00 - 15 Feb 2018    Post subject: What? Reply with quote
All very good if you match it with his £9gazillion squid wheel alignment tool. More a deal for monkey spunk chain lube. If he had real acumen he'd have gone with Deborah and the squeezy lube idea!
Some bikes.
Wonko The Sane
PostPosted: 18:06 - 15 Feb 2018    Post subject: Reply with quote
more pointless than spokey-dokeys
you stick the wheel in, give it a spin, if the chain is slack, pull the back wheel back a bit more, done.
It's a fit and forget is a pushbike chain, you'll have the wheel out for a puncture or tyre replacement before you wear the chain out.
anything with deraliur gears it's irrelevant
PostPosted: 19:04 - 16 Feb 2018    Post subject: Reply with quote
Yes this. Silly dragon invested because of the potential bicycle market without realising how a bicycle really works.
They've been around for a while. A solution to a problem that doesn't exist.
el_oso
PostPosted: 11:39 - 17 Feb 2018    Post subject: Reply with quote
potential in the bicycle market?!? lol
Dragon must know that hipsters will buy this shit.
Doesn't exactly make adjusting the chain any easier. The hardest part is making sure the alignment is good.
Duke 390
Car: Jeep Wrangler 4.0L
Courier265
PostPosted: 14:07 - 17 Feb 2018    Post subject: Reply with quote
Just googled this... you can't be serious, £25 for something no one really needs....
The last post was made 6 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 17 - Page Size: 105.45 Kb
