Fast idle
richard hardwick
PostPosted: 22:17 - 15 Feb 2018    Post subject: Fast idle Reply with quote
Hi all have cbf 600 2008 fuel injected last night turned off to open shed door when restarted idling at2500 any ideas was file before this cables seem free and no leaks sprayed wd 40 around no change in engine speed any help appreciated
PostPosted: 23:15 - 15 Feb 2018    Post subject: Reply with quote
Cold Start activated.
FI do not use choke but increase fuel for cold starting and to raise the idle speed when cold.
There will be a temp. sensor to let the edu know when to cold start.
It could just be a one off glitch.
richard hardwick
PostPosted: 23:45 - 15 Feb 2018    Post subject: Reply with quote
Runs at 5000 cold then down to 2500 where is sensor pleasr
PostPosted: 10:36 - 16 Feb 2018    Post subject: Reply with quote
The engine temperature sensor that controls the on-off points for the cooling fan may be used.
I'm not familiar with bike FI. So you should Google the electrical schematic for you bike model and year. Any sensors will be shown there.
Or Google you bike model year and idle speed.
And combinations of that...
Do you need someone to Google it for you? Razz
O
davebike
PostPosted: 11:56 - 16 Feb 2018    Post subject: Reply with quote
Only Honda's I seen do this have a mechanical "sensor" operating on water temperature Common fault on ST1300 and YamTDM900 etc denotes low coolant level !
Dave
NC750Xdct + others at work !
davebike1@gmail.com
The last post was made 6 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 17 - Page Size: 44.26 Kb
