Battery charger long cable voltage drop cause issue?
Ribenapigeon
PostPosted: 13:16 - 16 Feb 2018    Post subject: Battery charger long cable voltage drop cause issue? Reply with quote
If I run the cable from a battery charger out to my shed say about 15mtrs, will the voltage drop cause an issue with charging?
Copycat73
PostPosted: 13:34 - 16 Feb 2018    Post subject: Reply with quote
possibly .. measure it with a multi meter to be sure.
caveat emptor
Triton Thrasher
PostPosted: 13:37 - 16 Feb 2018    Post subject: Reply with quote
It could possibly make charging take longer, but it will still charge.
Rrrrrrrrrrrrrrrrrr
PostPosted: 13:39 - 16 Feb 2018    Post subject: Reply with quote
It would be better (in terms of electrical efficiency, not necessarily safety or convenience) to run a mains extension cable out to the shed then plug the charger in there.
PostPosted: 14:18 - 16 Feb 2018    Post subject: Reply with quote
This.
Except you. could go all HSE and use armoured cable (SWA)
And a weather-proof plug and a socket. (For The Belt & Braces effect)
https://www.screwfix.com/c/electrical-lighting/cable/cat8960001?cableproducttype=armoured
PostPosted: 16:29 - 16 Feb 2018    Post subject: Reply with quote
The trouble with armoured cable is a) Cutting it. then b) Terminating it.
I'd just use arctic cable with an RCD on the end unless you intend to make it permanant. I'm assuming since you're considering running a long twin core DC cable out, you're not going to be walking/driving over it or shutting it in a door.
In that case, armoured would be the weapon of choice. Ideally buried. And make it a proper fused and RCD-ed spur out to your shed with a secondary consumer unit attached at that end.
PostPosted: 18:49 - 16 Feb 2018    Post subject: Reply with quote
I hacksaw to nearly the length then peel the plastic back and nip the armour to length using side cutters. It is only galvanised steel wire so not incredible tough.
RCD is a good idea. It would also save tripping your ring-main breaker and shutting down the telly and so bring forth all that is hell down on your arse when Enders or any of that other proletariat shite is being pumped into the house and she is watching it. Shocked
Islander
PostPosted: 22:10 - 16 Feb 2018    Post subject: Reply with quote
mpd72 wrote:
Yes, hugely.
DC voltage drops considerably even over short distances with thinner wires. I did the 12V electrics on my campervan and the idea is to use thicker cable and the shortest cable runs possible.
There are charts showing the drop for various cable thicknesses over distance.
Here's a calculator.
https://www.voltagedropcalculator.com.au/
There's no difference between AC and DC when it comes to voltage drop. It relates to Ohms law, the higher the current drawn , the higher the I2R losses likewise the smaller the cross sectional area of the cable, the higher the I2R loss.
Also, the higher the voltage for a given load, the lower the current needed - this is why AC is a huge advantage in transmission line systems. It can easily be transformed to higher voltage lower current and vice versa.
The easiest fix for this is to run a mains extension out, rather than a DC extension.
PostPosted: 23:43 - 16 Feb 2018    Post subject: Reply with quote
Sure, in the 19th century. Since about 1950 or so, ~800kV HVDC has been practical and preferable for transmission. However, we'd set up an AC grid by then, so out comes the Not Invented Here cognitive dissonance.
The issue is what voltage means when you're comparing DC to AC. With DC, it's a constant relationship between the two polarities. With AC, you end up fudging it as some root-mean-squared relationship, and for some of your wave, you're pissing away all your low potential in total transmission loss.
But OP doesn't need to know that. The tl;dr version is to transform household "240" AC to something like 20 kV DC, and pump that out to the shed. To be sure that you're getting it through, strip the wire ends and then grasp one in each hand. Be sure to do it quickly and firmly to minimise arcing. If you feel a slight tingle, you're good to step it down to your 12V charging circuit.
Islander
PostPosted: 01:02 - 17 Feb 2018    Post subject: Reply with quote
AC is slightly more efficient for domestic distribution once you've taken reactive losses into account. AC to DC conversion losses approach something like 20-25%, transformer losses are much lower. Where you do gain advantage with DC is over continuous long distances (fewer conductors, no 3 phase required and no skin effect - the whole CSA carries equal current) which is why the continental interconnects are DC.
It's been a while since I studied this stuff but nothing's really changed that much.
Pete.
PostPosted: 07:50 - 17 Feb 2018    Post subject: Reply with quote
All very interesting but talking about high-voltage AC and DC transmission doesn't address Parky's question.
Yes, at 12-15v there's a definite voltage drop problem over 15 metres if you keep the wire size the same. Use the heaviest wire you can find for it - double the cross-section half the resistance.
a.k.a 'Geri'
Copycat73
PostPosted: 10:06 - 17 Feb 2018    Post subject: Reply with quote
or buy a car charger with a fast charge er go higher out put .. so the voltage will be correct when it gets to the bike..
https://www.eurocarparts.com/ecp/p/car-accessories/winter-essentials/winter-maintenance/battery-chargers/?551770781&0&cc5_145
caveat emptor
PostPosted: 11:25 - 17 Feb 2018    Post subject: Reply with quote
You could do it all carbon neutral.
Set up a wood-fired steam boiler in the house.
Run your steam lines (out-going) and condensate (in-coming) to/from the shed.
Connect to a Steam Turbine or Reciprocating engine driven 12 V DC generator in the shed.
And connect to your charger.
You could also use an AC generator and run through an inverter/transformer to drop/regulate for 12v DC.
That may be more efficient and easier to find the parts.
I would recommend insulating both the out-going steam pipe and the in-coming condensate lines. You will save a lot of energy by doing so and wet steam tends to accumulate so making it more difficult to get back to your boiler. That can mean running excess pressure just for return flow. Crying or Very sad
bugeye_bob
PostPosted: 11:27 - 17 Feb 2018    Post subject: Reply with quote
Not if you are a sparky, it easier.
Triton Thrasher
PostPosted: 12:43 - 17 Feb 2018    Post subject: Reply with quote
Islander wrote:
It relates to Ohms law, the higher the current drawn. the higher the I2R losses.
Yes. Charging a bike battery is a low current draw.
I charge mine at 0.8 A, falling below 0.1 A approaching full charge.
15 m of 12 V circuitry makes no practical difference at all to charging at that rate, so long as you don't trip over it.
Rrrrrrrrrrrrrrrrrr
PostPosted: 12:47 - 17 Feb 2018    Post subject: Reply with quote
Build a giant Tesla coil in your basement and fit the bike with an induction charger. Simply park it close enough.
PostPosted: 12:58 - 17 Feb 2018    Post subject: Reply with quote
Craaaaaazy thought: take the battery indoors and charge it there.
If it's not holding a charge because it's buggered, buy another battery.
I realise these strategies will avoid a fite with your pikeyer neighbour, mind, so they may not apply to your particular situation.
Islander
PostPosted: 13:24 - 17 Feb 2018    Post subject: Reply with quote
I did answer it in my first post Razz
Ribenapigeon
PostPosted: 15:05 - 17 Feb 2018    Post subject: Reply with quote
I have permission from the Cooncil to bury a mains cable. But I just wanted a quick solution until I get round to it. I already have an overhead cable for the cctv so easy enough to string a charger cable next to it.
After some thought I've come to the conclusion that the voltage drop from either side of the circuit will essentially cancel each other out. IE measured from the battery there would be a drop as well so from the chargers circuitry point of view it would just bump up the current a little then at the other end of the circuit the voltage drop would be down to what the battery would require at its potential measured at its terminals.
What I was worried about was the drop would fool the charging circuit into reading the level of charge wrongly then give the wrong output and knacker the battery. Or worse.
Ribenapigeon
PostPosted: 15:08 - 17 Feb 2018    Post subject: Reply with quote
So when are we off to Dragons Den? Sounds like a winner to me.
Triton Thrasher
PostPosted: 16:55 - 17 Feb 2018    Post subject: Reply with quote
Don't want to sound obvious, but why not just try it and see. It won't knacker the battery, whatever other "problem" it might cause.
Rrrrrrrrrrrrrrrrrr
Ribenapigeon
PostPosted: 20:46 - 17 Feb 2018    Post subject: Reply with quote
Worth asking the BCF'ers first. The usually something interesting to learn.
Triton Thrasher
PostPosted: 22:36 - 17 Feb 2018    Post subject: Reply with quote
There has been, but not much about your long leads.
Rrrrrrrrrrrrrrrrrr
The last post was made 6 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.71 - MySQL Queries: 17 - Page Size: 137.84 Kb
