Swinging arm bodge
Courier265
PostPosted: 21:50 - 22 Feb 2018    Post subject: Swinging arm bodge Reply with quote
https://www.facebook.com/SPORTSBIKESHOP.co.uk/
Just seen a very interesting swinging arm bodge....
M.C
PostPosted: 22:43 - 22 Feb 2018    Post subject: Reply with quote
Link to the actual post... https://www.facebook.com/SPORTSBIKESHOP.co.uk/posts/10156232992335929
Quality work Thumbs Up
duhawkz
PostPosted: 23:18 - 22 Feb 2018    Post subject: Reply with quote
That swing are is up there with bodyforms welded front sprocket, and who can forget the legend that was shervin and his zx10r mods
PostPosted: 02:26 - 23 Feb 2018    Post subject: Reply with quote
I'd love to see a coppers face when he pulled that over for whatever. Laughing
Frightening what some people will do.
Triumph Trophy Launch Edition
bugeye_bob
PostPosted: 10:09 - 23 Feb 2018    Post subject: Reply with quote
why not slide the ali inside and bolt up, bit of tape or a sticker to cover the crack lol
Hong Kong Phooey
PostPosted: 15:46 - 23 Feb 2018    Post subject: Reply with quote
Why bother with all that when you could just chop it back for single sided swing aesthetics. Wink
Triton Thrasher
PostPosted: 16:04 - 23 Feb 2018    Post subject: Reply with quote
Should have chopped the other leg off and taken the opportunity to re-angle that broken one as a fashionable gull arm.
Rrrrrrrrrrrrrrrrrr
PostPosted: 16:30 - 23 Feb 2018    Post subject: Reply with quote
Be interesting to stick it in a press and see which side caves first. I bet the total mass of alloy in those "splints" exceeds what you'd find in a modern swingarm. I'd want two bolts each side of the crack on that top one though to prevent rotation.
Mind you. Are those even actual bolts? or are they those course threaded coach bolt things you use for wood?
dydey90
PostPosted: 09:45 - 25 Feb 2018    Post subject: Reply with quote
Yep, those are self tappers. Fine for wood, where you’re going into a deep and soft material, but I doubt that swingarm is thicker than 3mm.
If he’d stuck a bar on either side and bolted it through properly, then it would probably be stronger than the original.
The last post was made 6 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.73 - MySQL Queries: 17 - Page Size: 61.34 Kb
