Shinigami |
Shinigami World Chat Champion
Posted: 16:42 - 23 Feb 2018 Post subject: |
CBA wading through construction and use regs. This is from the MSVA manual (.pdf file). if I built a one-off new bike, this would be the requirement to build it to so I'm assuming it paraphrases the C&U requirements.
FRONT INDICATORS:
Min Height: 350mm.
Max height: 1200mm.
Min distance apart: 240mm.
REAR INDICATORS:
Same heights as above.
Min distance apart 180mm.
Max 300mm from rear.
Should be visible from a position 2m from the front of the vehicle and 1.5m off the ground.
Flash between 60 and 120flashes/min.
On a side note. Those cheap integrated lighting units are utter shit and I'd put money on the flasher bulbs not lasting past the end of the road. Maybe double that for the headlamp bulbs.
The standard stanley headlight is actually pretty good on the GPZ500.
Sneaks off to measure the distance between the sidelights on his enfield bullet to see if he can put flashers in them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Shinigami |
Posted: 17:49 - 23 Feb 2018 Post subject: |
the one linked was just an example, I'd quite like that style on the front, not necessarily that unit.
Good info there though cheers fella ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
"Once you realize what a joke everything is, being the Comedian is the only thing that makes sense. |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 18:55 - 23 Feb 2018 Post subject: |
Laws or not, since I nearly SMIDSY'd a mate on a mini-cator clad blandit on a mini-roundabout not far off, 'cos the indies were a) far too close together to see, b) too close to the headlamp to see c) blotted out by a dim DTRL to see, and I was actually LOOKING for the ruddy things!
I really appreciate conventional old fashioned Indies on LONG stalks.
End of the day, if you are going to fit-em, whatever regs you might fiddle, the indies are there to tell folk where you are going..... you don't have a wonderful chance to start with, so give yourself the BEST chance you can, or just don't bother at ALL!
Bikes built before '84 don't need indies under C&U granddad rights. Bikes built after 'may' get away with them removed under "Adapted for off-road-use" caveot of modern regs.... and Hand-Signals WORK!!!!
Oh-Kay they confuse the hell out of any-one who passed a driving test in the last quarter century, wondering what a wounded-sparrow impression means..... but at least they see it and slow down!
You pays your money and takes your chances... BUT, IDGAS how cool they may or may not look, like I say, its down to chances and IF fitted, I want them to stand best chance of actually making other traffic NOT drive into me! So long stalks! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
ThatDippyTwat |
Shinigami |
Posted: 19:35 - 23 Feb 2018 Post subject: |
that looks decent, how did you make the bracket? Is it internally threaded rod bent round? ____________________ Current: Honda City Fly CLR125 2003 Honda CB600F Hornet 2008 Yamaha FZ6 S2 + 1991 Kawasaki GPZ500
Wonko The Sane |
Wonko The Sane World Chat Champion
Posted: 21:34 - 23 Feb 2018 Post subject: |
I agree with the bit of Teff's post that I read.
I nearly smashed the car into a pug 206 a few years back, they had one headlight working, bit brighter than it usually would be and the other the bulb was half gone, sidelight only.
on the 206 the indicator is small and sandwiched between the radiator grille and the headlight, due to the brighter single working headlamp, I could hardly see the indicator flashing until the moment crisis was averted.
It would actually dissuade me from buying a bike if the indicators were right next to the headlamp. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
The last post was made 6 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
