Hornet 250 Swingarm Bearings
MikeKP61
PostPosted: 23:03 - 27 Feb 2018    Post subject: Hornet 250 Swingarm Bearings Reply with quote
Hey lads, its a long shot but just wondering if anyone has ever swapped out the bearings on the 250 Hornet swingarm? Mines quite worn (can feel it getting squirly on banking and there's play when moving it axially) but neither Honda nor AllBalls has a kit listed for the set. My last resort is pulling it apart and getting a matching set from a bearing supplier but that means making my bike unusable for a couple of weeks which is an annoyance as it is my daily bike. If anybody knows the sizes of the bearings or anywhere that does a set it would be greatly appreciated. Many thanks,
Mike
ThatDippyTwat
PostPosted: 23:11 - 27 Feb 2018    Post subject: Reply with quote
Import?
David Silver Spares list 1996-2001 Might be worth a look.
https://www.davidsilverspares.co.uk/
Kawasaki Jimbo
PostPosted: 23:28 - 27 Feb 2018    Post subject: Reply with quote
https://www.bike-parts-honda.com/pieces-honda-detail-90062-90062-CB250FX-1999-F_22-CB+250+HORNET.html
Click on the part number and it suggests it's the same as the 600.
MikeKP61
PostPosted: 04:23 - 28 Feb 2018    Post subject: Reply with quote
ThatDippyTwat wrote:
Import?
Checked DSS and it wasn't listed Sad
MikeKP61
PostPosted: 04:24 - 28 Feb 2018    Post subject: Reply with quote
Kawasaki Jimbo wrote:
I've never seen this site before, it's a god send! Gives the bearing sizes and part numbers, that's all I'll beed for the bearing shop down home. Your a life saver thank you, I'll let you know how it goes
steve the grease
PostPosted: 12:21 - 28 Feb 2018    Post subject: Reply with quote
There is also cmsnl.com which has pictorial diagrams for Honda , Suzuki, Yamaha and Kawasaki.
for example :
https://www.cmsnl.com/honda-cb250f-hornet-1999-x-japan-mc31-115_model49453/partslist/?model_q=250+hornet
They are based in the Netherlands , so the postage costs a bit.
nowhere.elysium
The Pork Lord
PostPosted: 13:06 - 28 Feb 2018    Post subject: Reply with quote
Alternately, measure the bearing race size, and order them from a bearing manufacturer. 99.99% of bearings will be of a typically available size.
temeluchus
PostPosted: 01:21 - 03 Mar 2018    Post subject: Reply with quote
looks like you need a 6002 ball bearing, hmk2230 and hmk1720 needle roller bearings.
PostPosted: 11:03 - 03 Mar 2018    Post subject: Reply with quote
You don't generally have to wait for bearings from a bearing factors. It's a part of the business that when a machine in a factory shits a bearing, they need it NOW, if not sooner because theri whole factory just stopped. Having the exact bearing in stock for immediate collection is what gets and keeps them business.
So, if I were doing such a job, I'd plan it so I took the old ones out the night before and go to the bearing factors first thing to pick up the new ones.
My local one has only been beaten once, admittedly it was a Honda motorcycle bearing but a really oddball one from the stub-axle on a single side swingarm.
kramdra
PostPosted: 19:22 - 03 Mar 2018    Post subject: Reply with quote
Unless it is a honda, where I need fancy oversized 6004D45 https://www.wemoto.com/parts/picture/hl-961992/ for the front wheel where the standard and previous model would be 42mm. I assume they cocked up the wheel castings and had to bore it out bigger yet did not want an extra part of a sleeve in there BOM. Bearing factors do not carry this part, but it has became common in motorcycle parts shops because of this one model of Honda.
I think the rear wheel or sprocket carrier is also a non standard but cant remember what...
nowhere.elysium
The Pork Lord
PostPosted: 10:35 - 04 Mar 2018    Post subject: Reply with quote
Congratulations, you've highlighted the 0.01% I referred to. Is this the bearing that the OP is after, though?
temeluchus
PostPosted: 00:26 - 05 Mar 2018    Post subject: Reply with quote
All the bearing sizes are listed, clearly in the parts diagram. Just saying.
MikeKP61
PostPosted: 01:09 - 07 Mar 2018    Post subject: Reply with quote
They are indeed, only snag is I think the 6002 is a spurious part, isn't that code usually followed by 2 letters like RS or NS or something? The problem I have with dropping into the bearing place while doing the job is I can only work on the bike on weekends and the bearing shop in Limerick is closed then. I'll be popping in with the diagram to see if he can sort me, also need oil seals too so I'll put up a full list when I'm done for future reference. Thanks guys
temeluchus
PostPosted: 06:22 - 07 Mar 2018    Post subject: Reply with quote
https://simplybearings.co.uk/shop/product_info.php?products_id=152882&vat_inc=true&gclid=CjwKCAiAlfnUBRBQEiwAWpPA6dAgc_nNUCy2kwGnSq2BmH_nNLw-pNLgEID9tvEvf8LqqZjiNTXKNRoCx2sQAvD_BwE
no, its a standard bearing. No code means its an open bearing. RS, Z etc refer to shielded bearings with metal shields or rubber seals, and other numbers are for speed ratings. A swingarm bearing is a very low load so doesn't require anything fancy.
MikeKP61
PostPosted: 01:34 - 23 Mar 2018    Post subject: Reply with quote
Found the cause of the squirly back end anyway, some job getting what was left of the outer race out. Bearings from the diagram above are perfect size, should be back together by next weekend. Shock mount bearing was also seized up so have that out too.
PostPosted: 16:03 - 23 Mar 2018    Post subject: Reply with quote
Good lord - that's impressive. I would imagine that whatever sleeve that was running inside that bearing ids also 'fubarred'..
MikeKP61
PostPosted: 16:38 - 23 Mar 2018    Post subject: Reply with quote
The sleeve had a ball of corrosion on it but I polished it back to life, it's harder then the needles by the looks of it because the needles were ground down to a fine dust Razz
MikeKP61
PostPosted: 06:55 - 10 Apr 2018    Post subject: Reply with quote
Swingarm fixed, all bearing sizes were correct except the needle roller bearing on the chain side of the swingarm. Mine actually has 2 bearings of roughly 18mm length as opposed to 1 bearing of 30mm. Thanks again for the help lads.
PostPosted: 07:51 - 10 Apr 2018    Post subject: Reply with quote
Just take the old bearing to a bearing supplier as a sample.
Shocked
The last post was made 6 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 17 - Page Size: 109.82 Kb
