Quick Wheel Bearing Grease question
BananaLover
PostPosted: 19:39 - 09 Mar 2018    Post subject: Quick Wheel Bearing Grease question Reply with quote
I have to take off my wheel and figured could get the bearings greased while I'm at it, looking at a budget grease found this. I didn't have any luck finding a motorcycle specific one just wondering can I use this one for the job. Thanks
Howling Terror
PostPosted: 19:45 - 09 Mar 2018    Post subject: Reply with quote
Hi,
So what bike have you got and why can't it have sealed bearings?
BananaLover
PostPosted: 19:51 - 09 Mar 2018    Post subject: Reply with quote
Howling Terror wrote:
Hi,
I have a yamaha dragstar 650, I was watching a video tutorial on the same bike to remove the wheel and he suggested to grease it using the same brand grease, I couldn't find the specific on he used though, just wanted to make sure this one is fine.
I don't know whether I have to or not, I'm just following his tips.
Copycat73
PostPosted: 21:17 - 09 Mar 2018    Post subject: Reply with quote
any lithium grease will be fine
and this stuff https://lucasoil.com/products/grease/lucas-x-tra-heavy-duty-grease i would have no problems using what so ever ...
caveat emptor
BananaLover
PostPosted: 12:33 - 11 Mar 2018    Post subject: Reply with quote
thanks mate
PostPosted: 14:58 - 11 Mar 2018    Post subject: Reply with quote
I've never understood why they don't just come from the factory with sealed bearings fitted. May already have been done anyway.
temeluchus
PostPosted: 22:08 - 11 Mar 2018    Post subject: Reply with quote
I’ve always assumed that the factories bought a colossal supply of open bearings and seals in bulk and have been working through them for the past 40 years.
kgm
PostPosted: 22:16 - 11 Mar 2018    Post subject: Reply with quote
My er6 had an open bearing for the sprocket carrier. The wheel bearings are sealed. Needless to say the open bearing didn't like water much so I replaced it with a sealed one.
That said even my 38 year old cx500 came with sealed wheel bearings
Fizzer Thou
PostPosted: 17:05 - 13 Mar 2018    Post subject: Re: Quick Wheel Bearing Grease question Reply with quote
Whatever you buy,make sure that you do not use copper based grease as some people appear to use this stuff for just about everything.
I buy my new bearings from a local bearing specialist.They advised that when regreasing existing bearings,do not pack it out,as this can cause problems.
As for which grease I use for bearings,whether for head races or wheels,I reach for a jar of HMP grease.This is specifically for wheel bearings as it has a higher melting point and is still waterproof.
Halfords sell a variety of Castrol greases.The labelling on the canister is a helpful guide Thumbs Up Wink
Always have a 'Plan B'
The last post was made 6 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 17 - Page Size: 64.65 Kb
