Proc |
Proc L Plate Warrior
Pjay |
Pjay World Chat Champion
Pjay |
........ Borekit Bruiser
andys675 |
andys675 World Chat Champion
Posted: 12:08 - 12 Mar 2018 Post subject: |
Pjay wrote: | First thing I'd check is the three things you need to get the bangs going.
Fuel, Air, Spark.
A clean airfilter - remove it for a quick test, if it runs good, job jobbed, replace.
New spark plugs - cheap and always a good thing to renew.
Fuel, check your filter isn't clogged, even a bit can mean a lot at higher revs. |
this, there is nothing wrong with a cheap hiflo airfilter if genuine pricey, plugs can be had cheap on ebay just buy from someone you know like m&P or demontweeks, and check there isn't both a fuel filter inside and outside the fuel tank? ____________________ Some people feel the rain, others just get wet. |
Proc |
Posted: 14:13 - 12 Mar 2018 Post subject: |
@Pjay; thanks a lot for the comprehensive response. I'll check the air filters and fuel filters this evening and failing that I'll go onto spark plugs.
@garybee; I definitely could get the front wheel to float under hard acceleration in first/second gears. It's certainly lost some of its kick
@andys675; thank you for the advice. I'll bear that in mind if the problem is the filter.
I'll keep you updated in case you're interested to hear the outcome
Thanks again |
andys675 |
kramdra |
kramdra World Chat Champion
temeluchus |
The last post was made 6 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
