yamaha xs500 - Cam chain questions
Jay2903
PostPosted: 03:17 - 31 Mar 2018    Post subject: yamaha xs500 - Cam chain questions Reply with quote
Hey Guys
I've got a 75 xs500. Its leaking oil from the head on the left side and stutters at around 6k. I'm gonna replace the gasket to sort the oil leak and take a look at the valves for that stutter. The manual says the cam chain has to be split to remove the head and that a "special yamaha service tool" should be used ,it also shows some sort of homemade G clamp set up as an alternative.
Q1 - Is there a good of the shelf alternative i can buy to remove the cam chain master link ?
Q2 - Do i need to replace the masterlink with a new one when i re join it ? (the link cost £40 btw)
Any help greatly Appreciated
cheers
Jay2903
PostPosted: 02:31 - 01 Apr 2018    Post subject: Reply with quote
I've removed the master link now...
anyone know if it needs to be replaced when rejoining ??
Speedy23
PostPosted: 20:07 - 01 Apr 2018    Post subject: Reply with quote
Yes. Position the new link on top of the cam sprocket and support it from the back with something like a lumphammer etc. You can then use a broad centre punch to peen the ends of the pins over (IIRC, they should already have punch marks on the ends of the pins) when you have put the outer plate of the link on - but don't go mad, you're only holding the side plate in place, not seizing the new link solid.
Jay2903
PostPosted: 02:33 - 03 Apr 2018    Post subject: Reply with quote
ahh i see, thanks mate
Ed Case
PostPosted: 15:32 - 03 Apr 2018    Post subject: Reply with quote
On the down side these XS500 Yams were noted for carrying their oil on the outside, lotta leaky problems.
Jay2903
PostPosted: 19:16 - 03 Apr 2018    Post subject: Reply with quote
yea, the gasket i bought says -
"This gasket was the final design Yamaha came out with to both seal the oil leaks and stop the heads cracking from overheating. It supercedes all other versions. The purpose of the metal piece is to wick away the heat from the hottest front part of the thin cylinder head."
i have hope.
There is a gap of 3 years, 110 days between these two posts...
Madrugas
PostPosted: 20:48 - 21 Jul 2021    Post subject: Reply with quote
Hi,
I have a CS500 1H2 from 77.
I can’t find a camshaft shain for it.
Can some one please help me?
Alex
yen_powell
PostPosted: 21:14 - 21 Jul 2021    Post subject: Reply with quote
Try googling Galea Camchains, Tony Galea has all sorts of cam chain on rolls.
Galea Cam Chain Services
5.0
6 Google reviews
Motorcycle repair shop in Wickford, England
Address: Unit 15, Andersons Industrial Park, Lower Park Road, Wickford SS12 9EJ
Hours:
Closed ⋅ Opens 9AM Thu
Phone: 07860 152188
XT1200Z and a DR350 in bits
The last post was made 2 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 17 - Page Size: 56.01 Kb
