CDI for Kawasaki ER-5 or GPZ500
ultimatechees...
PostPosted: 16:09 - 13 May 2018    Post subject: CDI for Kawasaki ER-5 or GPZ500 Reply with quote
I need a replacement CDI for my Kawasaki ER-5 (2000). I was wondering if this part is the same as for the GPZ500. I read on Bike Chat Forums the following: "You would need to check the ER5 ignition system is compatable with the GPZ CDI. Some have one pickup, some have two (there is a GPZ CDI of each type, you'd just need the right one)." (It's an old post, so I don't want to resurrect it.) [https://www.bikechatforums.com/viewtopic.php?t=162231]
The part number for the ER5 is 21119-1494, and has two pickups (at least, I assume the two prongs out the bottom are pickups!). The GPZ500 one that looks exactly the same has part number 21119-1408.
The GPZ part is about 40% the cost of the ER5 part, so if they are the same part then that would save me money!
Thanks Smile
PostPosted: 18:14 - 13 May 2018    Post subject: Reply with quote
GPZ one has a different advance curve but I'd expect it to broadly work.
The wire colours and order will not be the same though. It wont be plug and play. So you'd need to know exactly which model it's off and have access to a wiring diagram for that model so you can wire it in.
This is no mean feat, I think there are up to 10 wires you'd need to re-order correctly. Given the level of knowledge you appear to have (the bits sticking out of the bottom of the CDI are mouldings for the wiring terminal blocks). I'd suggest you just get a replacement ER5 one and plug it in.
ultimatechees...
PostPosted: 18:19 - 13 May 2018    Post subject: Reply with quote
Well it wouldn't actually be me fitting it, but rather the garage at which the bike currently is! Given the issues that you've outlined, I think I'll just go with the ER5 one. Thanks Smile
PostPosted: 18:24 - 13 May 2018    Post subject: Reply with quote
Definately. Wiring in a CDI off a different model is well beyond most motorcycle technicians. They are almost invariably utter crap at wiring/electrics.
It's unusual for a CDI to fail. I wouldn't be surprised if it turns out not to be your problem. The usual way motorcycle mechanics fault find is to randomly replace parts until it either starts working again or you run out of money.
ultimatechees...
PostPosted: 18:25 - 13 May 2018    Post subject: Reply with quote
So he said that he didn't have the tools to test, but that someone comes in once a week with the testing kit. When this person came, they found power all the way up to the CDI, but then no power past the CDI...
Chris45
PostPosted: 20:45 - 13 May 2018    Post subject: Reply with quote
You got that right. Incidentally the ER model is a slightly detuned version of the GPz engine, so I guess there would be quite a few other electrical issues to resolve prior to fitting. I have the manual so I'll have a check over the differences in electrical output.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
Chris45
PostPosted: 21:41 - 13 May 2018    Post subject: Reply with quote
Just checked the Haynes electrical diagrams and the guys are right. While the connector pins look similar by number, they are totally different in colour. I wouldn't even contemplate the idea of using one off a GPz.
sickpup
Old Timer
PostPosted: 22:10 - 13 May 2018    Post subject: Reply with quote
The only reason a CDI would go on an ER5 and it is common is if the reg/rec went first. taking out the resistor on the ignition barrel as well.
The rev counter is probably gone as well.
ultimatechees...
PostPosted: 08:03 - 14 May 2018    Post subject: Reply with quote
Thank you very much, I most certainly won't try it!
Thanks everyone for their help and advice Smile
temeluchus
PostPosted: 13:17 - 14 May 2018    Post subject: Reply with quote
id generally suspect the coil/leads/plugs/wiring before id look at the ignitor.
ultimatechees...
PostPosted: 13:19 - 14 May 2018    Post subject: Reply with quote
Even with there being power all the way up to the CDI, but not past it?
stephen_o
PostPosted: 15:01 - 14 May 2018    Post subject: Reply with quote
Have you checked your resistance wire from the ignition switch to the computer - mine failed twice and the computer was suspected before it was checked to find the wire had burnt out.
current scoot 2009 Yamaha YBR250 + Current Pootle 2013 Nissan Leaf
PostPosted: 15:18 - 14 May 2018    Post subject: Reply with quote
In fairness, it is a very overcomplicated system.
One thing that could also give you no CDI output is a faulty safety interlock. So a problem with the clutch/sidestand/neutral switch and associated wiring.
ultimatechees...
PostPosted: 17:57 - 14 May 2018    Post subject: Reply with quote
So one other thing that I read was the following. (I don't remember exactly where.)
I have finally found the cause for the no spark.
The ER5 ignition switch has an anti hotwire device added.
This device is a simple resistor that the ECU looks for.
I am still using the old ignition switch without the resistor.
I just wired the resistor in line to the wire that goes from the ignition to the ECU.
And now I have spark how good is that.
Is this the resistance wire you're mentioning?
A mouse decided to make its home in my bike and ate through some cables. Seem reasonable that maybe the wire in question has been gnawed?
stephen_o
PostPosted: 19:30 - 14 May 2018    Post subject: Reply with quote
YES! on my GPZ it was wrapped in the wiring loom and had to be seperated down the full length of the run in order to find the break/burn out and then patch it up.
ultimatechees...
PostPosted: 19:35 - 14 May 2018    Post subject: Reply with quote
I've just found out the following additional information. When it was tried to be started, their positive crocodile clip from their van's battery touched against the frame when the negative was connected, and there was an almighty spark. Apparently that can destroy the CDI.
It does sound from what you people have been saying that it could just be the wiring though...
The last post was made 7 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 14 - Page Size: 89.34 Kb
