Rear wheel brakes binding
Sammydroid
PostPosted: 20:35 - 07 Apr 2018    Post subject: Rear wheel brakes binding Reply with quote
I just recently changed the rear pads on my daelim roadwin (13 plate)
Everything seemed to go well but now with everything torqued up the wheel takes physical force to turn
If i loosen the caliper bracket bolts off slightly, the binding stops and the wheel moves a bit more freely allbeit still a bit stiff
The previous rear wheel on this bike was buckled (ive mentioned this in another post) could this have bent the bracket maybe?
Islander
PostPosted: 21:22 - 07 Apr 2018    Post subject: Reply with quote
It sounds like your caliper isn't moving freely on the slider pins.
Take the caliper off again, and pull it off the mounting bracket (it should slide off easily but it probably won't. Remove the rubber boot that goes through the caliper and clean any oxidisation out of the hole. Grease the pins with some silicone or red rubber grease and reassemble.
Sammydroid
PostPosted: 16:56 - 08 Apr 2018    Post subject: Reply with quote
Cheers for that
I’ll try that and see how i get on
Howling Terror
PostPosted: 17:01 - 08 Apr 2018    Post subject: Reply with quote
I take lots of photos, lay the parts out as they're taken off. Plenty of jobs can be done using that method.
Sammydroid
PostPosted: 18:57 - 11 Apr 2018    Post subject: Reply with quote
it was one of the slider pins in the end so "islander" you were spot on (sorry not worked out how to tag names or anything like that Smile )
the boot had a hole in it and from the amount of build up ive removed from the slider pin housing its been like that for a bloody long time
took a lot of hard work to get out though ha ha
thanks for the advice really appreciate it, saved me the cost of a whole caliper vs a new slider boot
The last post was made 6 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.09 - MySQL Queries: 17 - Page Size: 44.91 Kb
