Concerns and Questions about my new Dual sport Tyres.
tenacious1996
PostPosted: 23:05 - 10 Apr 2018    Post subject: Concerns and Questions about my new Dual sport Tyres. Reply with quote
Hi there!
I'm Totally new here, and this is my first Post. apologies in advance
if I have managed to put this in the wrong section. I looked closely at the rules, so I hope I've got it right!
I'm hoping that someone could help me out a little with some issues I'm having with the set of Michelin Anakee Wilds that I bought for My Honda CB125F -aka- GLR125.
So, the issue that I'm facing-
I'm unsure if my new tyres are Safe to run without tubes or not.
My order Describes them as "110/80 18 - 58s - TT/TL"
I've managed to put the front one on with ease. It Inflated and it looks as though it has seated nicely. It took a bit of rapid pumping because I'm using a basic Bicycle pump, but other than that, No visible issues.
However, I noticed the sidewall of the tyre reads "TUBETYPE"
This is the part that's confusing me a little bit, because on my order invoice it clearly describes them as TT/TL. I'm assuming that this means it's suited to be used with or without a tube - depending on if the rims require tubes. But I'm no expert.
I know that tubeless tyres have a different shaped bead than tube type ones, so I compared the bead on the Anakee's with the bead on My old tyres, and there's no difference from what I can tell.
However my uncertainty is leaving me reluctant to ride anywhere until I'm sure that the tyre isn't going to Blow out, or separate itself from the rim at 60mph and cause an accident or something.
I inflated the tyre a little more, and I will be checking on it again in the morning to check that it hasn't lost any pressure.
If someone could help me out, I would totally appreciate any kind of advice, thoughts or anything at all honestly. I have no idea what to do Very Happy
uberkron
PostPosted: 02:50 - 11 Apr 2018    Post subject: Reply with quote
I thought the wheel type dictated tube or no tube.
Ie spoked doesn't hold air so does need a tube.
Where as an alloy wheel does hold air.
What's holding your valve in the wheel?
i ride a zip 50 2smoke. It overtakes a hundred times a day.
tenacious1996
PostPosted: 08:27 - 11 Apr 2018    Post subject: Reply with quote
The wheels are cast aluminium with a valve built Into them. They are tubeless, for sure. I'm just unsure if my new tyres are tubeless + safe to run. They do read ''tubetype'' on the sidewall. But this is contradictory to what the Michelin website and my order invoice states.
Copycat73
PostPosted: 08:39 - 11 Apr 2018    Post subject: Reply with quote
if it says tube type on the side wall...then i`d put an innertube in.
caveat emptor
tenacious1996
PostPosted: 09:11 - 11 Apr 2018    Post subject: Reply with quote
Okay, I'll definitely Consider going with a tube. I'd like to avoid that if I can though. I've had a few tubed tyres rapidly deflate while on the dual carriageway. needless to say I didn't enjoy that experience. If I can't run them without tubes, I'll probably end up selling the tyres on.
tenacious1996
PostPosted: 09:44 - 11 Apr 2018    Post subject: Reply with quote
Just checked back this morning, and it appears the tyre hasn't leaked or anything. A few photos here too.
https://ibb.co/hyAApx
https://ibb.co/gQXqpx
https://ibb.co/goV72H
Copycat73
PostPosted: 14:17 - 11 Apr 2018    Post subject: Reply with quote
mpd72 wrote:
Can you do that if the rim already has a valve for tubeless? Is it just a case of removing the existing valve and poking the inner tube valve through the hole?
well thats what i`ve done in the past ....and still here to tell the tale...
caveat emptor
PostPosted: 14:36 - 11 Apr 2018    Post subject: Reply with quote
Drop an email to michelin uk and ask.
For me, it would be a bigger sin to run a tube only tyre without one than to put a tube in a tubeless. Always use a heavy duty tube in a tubeless tyre.
PostPosted: 14:59 - 11 Apr 2018    Post subject: Reply with quote
Tyre look pretty knobbly to me - planning on doing much off-roading?
Copycat73
PostPosted: 16:56 - 11 Apr 2018    Post subject: Reply with quote
it seems to be a fashionable accessory to fit off road tyres to an otherwise road goin bike ...
fcukin hypster type modification .. wonder if you get a free "nice beard" with every pair ....
caveat emptor
tenacious1996
PostPosted: 19:02 - 11 Apr 2018    Post subject: Reply with quote
lol. While it does seem to be a sort of trend to fit Knobbly Tyres to road-going bikes, off-road riding is inevitable around where I live. Lots of narrow track roads, and a few open fields to have a muck about in. its only a 125, so achieving anything above 70mph isn't going to happen. so I decided that if I can't go fast, I'll Just go anywhere instead.
the 50/50 tyres seemed the most logical to me at the time. + they were on sale. Very Happy
Suntan Sid
PostPosted: 19:29 - 11 Apr 2018    Post subject: Reply with quote
This is not always the case.
My GasGas trials bike had spoked wheels suitable for tubeless tyres!
PostPosted: 19:40 - 11 Apr 2018    Post subject: Reply with quote
Your opinion will probably change once you've had the chance to ride them on a damp road. Laughing
PostPosted: 19:54 - 11 Apr 2018    Post subject: Reply with quote
Tubeless tire have a tube.
It is a soft lining bonded to the inside with extends over the head to provide a seal for when the tyre is inflated.
As has been said, fire an email to Michelin UK or call them. They have phones too. And a lot of them speak English too not just French. Very Happy
tenacious1996
PostPosted: 20:09 - 11 Apr 2018    Post subject: Reply with quote
How slippery are they exactly? I'm no stranger to riding in snow, ice/sleet etc. I'm okay riding in that sort of stuff when the threat of taking a fall is right in front of me. I'm useless when it comes to saving it after one of the tires suddenly changes its mind about being underneath the bike Very Happy
PostPosted: 20:29 - 11 Apr 2018    Post subject: Reply with quote
Knobbly tyres on damp roads are fine unless you want to stop quickly or turn quickly. Laughing
tenacious1996
PostPosted: 21:31 - 11 Apr 2018    Post subject: Reply with quote
Finished fitting the rear about 10 mins ago, and my useless little bicycle pump just can't get enough air in there quick enough to make the bead seal. oh well.
I think I'll take the much appreciated advice I've received from you guys, and pick up a couple of Decent tubes. Then its just a matter of tackling the frustrating task that is correctly aligning my rear wheel Rolling Eyes
Thanks for all the help! Very Happy
PostPosted: 22:29 - 11 Apr 2018    Post subject: Reply with quote
If you are still keen.
Use a piece of rope as a tourniquet around the tyre.
As you tighten the tourniquet it displaces the tyre and pushes the head against the rim.
It is easier using a ratchet strap if you have one.
When the head is on the rim it seals and you can blow air in.
The last post was made 6 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 17 - Page Size: 108.45 Kb
