Coil Issues.
R1stu
Shrek!
PostPosted: 18:26 - 11 Apr 2018    Post subject: Coil Issues. Reply with quote
OK, guys, I have been having issues with the pan. She has not been revving cleanly and misfiring, and backfiring.
I've been told it is going be the coils, then I've been told it's going be the carbs. and get different answers depending on the time of day.
I have removed the carbs and cleaned them, as the idle jets were blocked it seems, and have removed the coils.
secondary resistance is within spec, however, the primary side I am getting a rating of 3.5 ohms.
The Haynes manual says the spec should be between 2.1 and 3.1 ohms.
Would being out by .4 make a big difference?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Tankie
PostPosted: 18:57 - 11 Apr 2018    Post subject: Reply with quote
Not really, but you could be on the right track, check for arching and make sure caps and plugs are in good order.
PostPosted: 19:06 - 11 Apr 2018    Post subject: Reply with quote
Your multimeter probably isn't accurate enough to give a reading within the benchmark anyway.
Coil is probably fine. the usual sign of a failing coil is it stops working when hot and starts fine when its cooled down enough.
R1stu
Shrek!
PostPosted: 19:15 - 11 Apr 2018    Post subject: Reply with quote
Mine is other way round, pain when cold, but when warm runs fine.
PostPosted: 19:45 - 11 Apr 2018    Post subject: Reply with quote
Have you considered the valve clearances? It's not unknown for clearances to tighten up. The symptoms are poor running and starting when cold but fine when warm.
jaffa90
PostPosted: 20:29 - 11 Apr 2018    Post subject: Reply with quote
What were the condition of the carb diaphragms?
R1stu
Shrek!
PostPosted: 21:47 - 11 Apr 2018    Post subject: Reply with quote
Valves gave been on my to do list. Been 20k since last checked.
The last post was made 6 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 17 - Page Size: 54.48 Kb
