kramdra |
kramdra World Chat Champion
fatjames |
fatjames World Chat Champion
DrDonnyBrago |
DrDonnyBrago World Chat Champion
Hong Kong Phooey |
kramdra |
kramdra |
DrDonnyBrago |
Posted: 15:23 - 21 Jun 2018 Post subject: |
kramdra wrote: | Backfires seem to indicate the fuelling issue is fixed and its time to restart the engine.
Can not remember how to get ithe das to give flash code. |
You need to jump the diagnostics connector under the seat, its a two pin female plug. From memory a green wire and a brown wire service it and its on the LHS not far from the ECU.
Turn the bike off, bridge connector with a paperclip or bit of wire, turn ignition back on. Read codes by counting flashes:
A long blink = 10
A short blink = 1
CODES:
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM. |
kramdra |
DrDonnyBrago |
kramdra |
Hong Kong Phooey |
kramdra |
The last post was made 5 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
