yoke nuts
HappyDays
PostPosted: 22:51 - 15 May 2018    Post subject: yoke nuts Reply with quote
Hi all,
What's the best way to check if the top yoke/stem is tight enough?
Just doing some checks and had very slight movement when you put the front brake on.
Liquorice Torpedoe
kgm
PostPosted: 22:54 - 15 May 2018    Post subject: Reply with quote
Tighten them till they feel right enough, or use a torque wrench to get them to the correct setting as per the service manual.
If you lift the front wheel clear of the ground whilst on the centre stand and push back and forward there should be no play (don't confuse movement in the stand for play). If there is the most likely thing is worn or loose steering bearings. If that's the case tighten the adjuster nut until it's only just right enough to remove any play but be careful not to over tighten.
HappyDays
PostPosted: 23:06 - 15 May 2018    Post subject: Reply with quote
So if the bars move left or right on there own, that's tight enough?
Liquorice Torpedoe
kgm
PostPosted: 23:27 - 15 May 2018    Post subject: Reply with quote
It should be tight enough to remove any front to rear play but not so tight as to restrict bar movement - if the bars are centred with the wheel in the air it should only take a very light touch on the end of the bars to start it turning. Essentially you want it as loose as possible without introducing play.
HappyDays
PostPosted: 23:56 - 15 May 2018    Post subject: Reply with quote
Cheers guys, just keeping up with the bits and bobs Mr. Green
Liquorice Torpedoe
PostPosted: 09:52 - 16 May 2018    Post subject: Reply with quote
Put your thumb on the bit where the frame headstock meets the steering and check for play, you should be able to feel even a very slight lateral movement. Careful not to trap your fingers in anything.
HappyDays
PostPosted: 12:06 - 16 May 2018    Post subject: Reply with quote
Also will this type c spanner do the lock ring yoke nuts?
https://www.ebay.co.uk/itm/3-piece-C-Spanner-Suspension-Adjusting-Spanner-Set-45-55mm-69-76mm-89-96mm/121591613239?hash=item1c4f6cc737:g:18EAAOSwBLlU~hiu
Liquorice Torpedoe
kgm
PostPosted: 13:15 - 16 May 2018    Post subject: Reply with quote
Probably but every bike is different. At a push you can use a hammer and screwdriver but that wouldn't be my recommendation.
PostPosted: 14:21 - 16 May 2018    Post subject: Reply with quote
Those tools will probably work ok. Have you checked in the bike toolkit though?
I have an adjustable c-spanner that covers quite a few sizes of nut.
HappyDays
PostPosted: 16:30 - 16 May 2018    Post subject: Reply with quote
I did check the tool kit and it had a c spanner for the shock but to small for the stem nuts. Think I might get them from ebay as looks ok.
Cheers anyway guys, very helpful Thumbs Up
Liquorice Torpedoe
The last post was made 8 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 64.94 Kb
