Possible injector issues???
ninjameaniekt...
PostPosted: 12:19 - 11 May 2018    Post subject: Possible injector issues??? Reply with quote
Hello Comrades
So my bike after starting and running for about 15 seconds was sounding sluggish and then died. Im now in the process of diagnosis. Here's what I have so far but would appreciate help and general direction I should pursue if anyone has had similar issues.
Bike details: new battery, 45000 miles, ZX6R p8f model 2008
I have found the the injectors are not spraying fuel. Any reasons why? I think the fuel line is pressurized and the pump works. The spark plugs all fire correctly. Im guessing and electrical issue but before I delve into the nightmare that Is the wiring loom is there anything that would stop the injectors passing fuel? I just used some paper towel to see if they were opening on pressing the engine start button but it was dry after a few false starts.
Many thanks
Kawasaki Ninja ZX6R, Kawasaki Meanstreak 1500, KTM RC8, KTM 450 SXF
Tdibs
PostPosted: 13:07 - 11 May 2018    Post subject: Reply with quote
Battery in decent nick?
Copycat73
PostPosted: 16:27 - 11 May 2018    Post subject: Re: Possible injector issues??? Reply with quote
Many thanks
dirty fuel filter .. my kawasaki has one inside the fuel pump inside the fuel tank.
caveat emptor
MCN
PostPosted: 17:40 - 11 May 2018    Post subject: Reply with quote
Be careful you don't inject fuel into your body. Smile
I haven't a scooby what controls that system.
Basic control is a pump sending fuel to the injector.
The injector being closed creates a pressure controlled by a relief valve.
The ecu sends current to the injector to open it.
Fuel sprays out.
(There can be more control on more sophisticated systems.)
So you could have:
A bad pump. (A PUMP CREATES FLOW IT DOES NOT CREATE PRESSURE.)
Bad fuel supply to injector/s (filter as said).
Bad relief valve. (CONTROLS PRESSURE.) Some pumps do not have a relief valve and output pressure is limited by the spring that drives the pump plunger. Max pressure is when the spring gets compressed and no longer moves the plunger.
Bad ECU. Bad power supply, earth, wet and all the other et ceteras.
ninjameaniekt...
PostPosted: 09:35 - 17 May 2018    Post subject: Reply with quote
Thanks guys - ill follow through with the advice and get back to you if im still at a dead end
PostPosted: 17:27 - 17 May 2018    Post subject: Reply with quote
Turn ignition on, listen for the pump priming for about 1-2 seconds. If it doesn't then either the pump is dead, the fuse is blown of the alarm is fubar.
If it has an alarm/immobiliser - suspect that first!
The last post was made 7 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 14 - Page Size: 48.61 Kb
